Code 31 With Carrier Weathermaker 9200 58mxa - HVAC - DIY Chatroom Home Improvement Forum
Old 01-24-2012, 09:05 PM   #1
Code 31 with carrier weathermaker 9200 58mxa
I've been having trouble with this furnace, I had a furnace company out and to get it going (it was about ) deg.)we had to unplug a couple of vacuum hose to the pressure switch and disconect the outside intake pipe for it to run, I got a new pressure switch and put it on, now what it does when I turn it on it fires fine, no code, then it cycles off and 10-15 minutes later it cycles on with the 31 code again ,it only purges this cycle then it stops without ignition and 10-15 minutes later it cycles on and fires great, no code problem . so is there a purge cycle on this furnace so it only fires every other cycle.
jbander is offline   Reply With Quote
Old 01-24-2012, 09:23 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
no purge cycle
research carrier class action lawsuit
unit should be examined by a licensed contractor
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 01-24-2012, 09:46 PM   #3
Check the condensate drain for a blockage. Sounds like water is backing up and when it sits it drains down and will allow the furnace to run for a short time.
dvenable is offline   Reply With Quote
Old 01-24-2012, 10:28 PM   #4
You may have a bad secondary heat exchanger.....they have a very high fail rate.....here is what to look for....
this is an actual picture of a failed secondary on a carrier 58 sx
harleyrider is offline   Reply With Quote
Old 01-25-2012, 12:09 AM   #5
Where do I look for secondary heat exchanger
I don't know were it is,is it were the burner is.
Old 01-25-2012, 12:13 AM   #6
That is clean and no water build up, Does this furnace have a purge cycle when the burner doesn't start or should it be firing every time.
It is working now , the house is warn and cozy but it has to cycle twice to get one heat cycle. Am I making this clear enough. I'm a little week on terminology.
Old 01-25-2012, 12:15 AM   #7
Originally Posted by hvactech126 View Post
no purge cycle
No it has two purge cycles one that doesn't light the gas with a code 31 and the next one works great PURGE, FIRE, BLOWER
Old 01-25-2012, 12:18 AM   #8
you CAN NOT see this area with out useing a high resolution in-fared HVAC camara......it is above or below (depending on your furnace oreintation) the blower.
Old 01-25-2012, 12:24 AM   #9
how
Rewards Points: 1,070
Hey Harley
Infra red???
Wouldn't a regular camera scope with a high intensity light show the same view of the heat exchanger that is posted?
how is offline   Reply With Quote
Old 01-25-2012, 12:28 AM   #10
Originally Posted by how View Post
Hey Harley
Infra red???
Whats wrong with a regular camera scope with a high intensity light?
yeah.....that will work as well............as a matter of fact, I took these pics with my cell phone after the heat ex was on the floor......i am guilty of "hyping it up a bit".....we do that so we can charge more.........
Old 01-25-2012, 12:45 AM   #11
Also that class action suit was up on aug 1 2008 ,I was never sent anything about that, was it my responsibility to find that out myself . My income doesn't include getting my furnace checked every year. I had a service man here I have no idea how qualified he was. I owe him money for coming out when it first went down. Do I call a carrier serviceman .
Old 01-25-2012, 12:51 AM   #12
Its working but
It has one purge cycle where it doesn't like giving me a 31 and 10-15 minute later it cycles and heats just fine. Is this ok or not.
Old 01-25-2012, 12:53 AM   #13
I have to say one thing you get instant help here, isn't the INTERNET great. Thanks guys
Old 01-25-2012, 12:53 AM   #14
i have made claims on that suit as close as 9 months ago, so i am assuming they extended it? I know for a fact that carrier is (was) still paying labor to replace them (have to jump through several hoops) as late as this past October. so i guess the moral of this story is.......DO GIVE UP!
Old 01-25-2012, 12:58 AM   #15
[quote=harleyrider;834062]i have made claims on that suit as close as 9 months ago, so i am assuming they extended it? I know for a fact that carrier is (was) still paying labor to replace them (have to jump through several hoops) as late as this past October. so i guess the moral of this story is.......DO GIVE UP![/quote
Why should I give up? or did you mean don't give up
Tags
furnace carrier
Carrier Weathermaker 9200 Codes 34/14 have ignition Hawxter HVAC 9 12-31-2011 04:02 PM
CArrier WeatherMaker 9200 Code 31 jhartmann1981 HVAC 12 12-17-2010 09:04 AM
Carrier Error Code 33 russell124 HVAC 4 12-04-2010 08:19 PM
code 31 Carrier 58MXA Mr. Break It HVAC 1 01-02-2008 11:24 AM
Carrier code 31 on 58MXA (WeatherMaker 9000?) SteveAnnArbor HVAC 7 11-05-2007 07:53 PM
