Old 01-01-2008, 12:17 AM   #1
code 31 Carrier 58MXA
Need some help here. New Years Eve. The Furnace is off it smelled a little electrical. The Motor (fan) is hot to the touch. The code light is flashing 31. The coaxial pipe appears clear (not visibly blocked and does have a screen over the end). The furnace and the home is only 2-1/2 years old this is the third winter. Never a problem before. First time I turned it off let it wait to cool down and turned it back on ran fine a while thought it was the wind or something. When out for a few hours, 5-6, came back to teh same situation. Two questions........ One is it safe to restart it and let it run to heat the house? Two, how do I fix it? Any help is appreciated here.
Mr. Break It is offline   Reply With Quote
Old 01-02-2008, 11:24 AM   #2
do some searching, I can't remember where i just saw this , however there is a class action suit involving Carrier, bryant and others, it may or may not be the cause of your problems
big daddy-o is offline   Reply With Quote
Carrier furnace help code 13 mudtruck HVAC 8 03-30-2013 04:09 PM
Carrier 58MXA pressure/vacuum problem gshock HVAC 8 01-17-2008 07:13 PM
Carrier 58MXA furnace problems bush HVAC 5 12-12-2007 09:42 PM
Carrier code 31 on 58MXA (WeatherMaker 9000?) SteveAnnArbor HVAC 7 11-05-2007 07:53 PM
