#1 |
code 24 on Carrier furnace
The error code light on my furnace is 24 which translates to short circuit on one of the wires or fuse is open. I've already replaced the 3amp fuse multiple times and it keeps burning out.....any suggestions??
I really don't want to call a tech and pay them $150 minimum. |
#2 |
An old Tradesmen
Look for a short in your low voltage wiring.
#3 |
how do i look for the short? do i have to have a meter?
#4 |
You can start by taking the t-stat wires off the circuit board including the 2 wires that run out to your a/c unit and see if the fuse still blows. that will help you figure out if you have a short in the a/c unit, t-stat or t-stat wiring. and if the fuse still blows you have a short in the furnace itself.
#5 |
perhaps another couple hundred fuses before you get the magic one
sorry couldnt resist |
#6 |
The condenser is a common location for this low voltage short...
| Tags |
heating furnace 24 error ![]() |
| Display Modes | |
| Carrier furnace help code 13 | mudtruck | HVAC | 8 | 03-30-2013 04:09 PM |
| Carrier Furnace Problem... | cornation71 | HVAC | 3 | 12-10-2009 08:52 AM |
| Carrier Furnace LED Code 34 and 14 | sherjack | HVAC | 20 | 11-01-2009 09:45 AM |
| Zoning With Carrier Infinity Furnace | ddartmouth | HVAC | 1 | 01-05-2009 12:55 PM |
| Carrier furnace fan wouldn't shut off | claymthomas | HVAC | 5 | 01-21-2008 07:39 AM |
