CO Test Kits - HVAC - DIY Chatroom Home Improvement Forum
Old 02-10-2009, 12:45 PM   #1
CO test kits
are the buttons that you can buy for 9bucks good test kits for checking on CO leaking from the exhaust of my gas appliances and around the house or would it be better to invest $150 on the meter tool from home depot?
spudgunman is offline   Reply With Quote
Old 02-10-2009, 05:32 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 2,286
Most people buy 2 good First Alert CO detectors and plug them in the wall. One downstairs and the other in your bedroom. A commercial grade CO tester/meter costs several hundred $$ from a heating wholesaler.
Old 02-10-2009, 05:40 PM   #3
well home depot has this 150$ tester 0-1000ppm and they sell the stickers that turn black and gret starting at 15ppm if right conditions. is this worth it to do some spot checking
(I already have a plug in wall unit and a Kiddy roof unit mounted) I just want to make sure that I am good as my exhaust for the system runs in the core of the building with some open plenum areas.)
Old 02-10-2009, 06:31 PM   #4
Hvac Pro
yuri's Avatar
I use this one:
http://www.ueitest.com/product-co71.html
Those test vial units etc can go bad with age and I would not trust any cheap CO tester. That UEI I have is tough as nails and works very well. Not sure what it costs now but you may as well buy a good one or the process is unreliable/inaccurate.
How to test new plumbing work for leaks Gusaroo Plumbing 5 07-14-2012 02:06 AM
New test being conducted! Still hvac issue! MrShadetree0222 HVAC 24 10-21-2008 10:44 PM
looking into dye kits/ bleach repair kits 4 carpets. any suggestions? flooring Flooring 3 09-02-2008 09:21 PM
Test kit for shower pan...HELPPPPP! tverhoef Plumbing 7 02-27-2008 10:12 AM
Radon Test! handy man88 Plumbing 2 10-18-2007 07:38 PM
