Old 12-05-2006, 11:42 AM   #1
closing vents in unused living space
Hello,
I have an upstairs that I don't use as living space so would like to leave unheated this winter if it makes sense and can save some money.
I know I can close the vents themselves in the upstairs rooms. I know I can also close the "valves" (for lack of a better term) in the air ducts themselves as they branch off into the various sections of the house originating from the furnace.
What I don't know is what the best approach is. Should I close only the vents, or only the valves, or both, or none? I have heard that closing off too many vents can cause the furnace to overheat. I have also heard that closing vents makes little difference because the furnace is callibrated to heat a certain square footage, and that's pretty much what it will do...the air will find somewhere to go even if the vent is closed (leaks in ducts, heat the space between the walls). I am not sure what to believe and what is just furnace folklore.
I have used foil tape to seal most of the ductwork in my house, as well as wrapped it in fiberglass insulation, only I couldn't get to the ducts that weren't accessible (in between walls). I have also weather-stripped and caulked windows and doors as much as possible, as well as added more insulation to the attic. The only cost-saving tactic I can think of is to not heat the upstairs, if it makes sense.
My goal is to save money this winter on heating costs.
Any input would be greatly appreciated.
Thanks,
Scott
scottydel is offline   Reply With Quote
Old 12-05-2006, 02:39 PM   #2
Thoroughbred Mopar Man
Hi scottydel
If your duct system was designed properly, when you start closing off ducts not only are you not saving any money, you are driving the temperature differential up. When this happens you are taking a chance a heat exchanger problems. Not knowing your system, I am making an educated guess.
Good luck
Rusty
#CARRIERMAN is offline   Reply With Quote
More On This Topic
Hi, I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. Something else you want to think about if you do decide to finish your basement in stages, is access to the plumbing and heating. If you decide to finish... Read More »
Hello, I'm Mark Blocker with Expert Village. In this segment were going to cover the heating and cooling system. In many of today?s new automobiles they have an air bypass valve installed on the cooling system. As I described before there is a thermostat... Read More »
Ice fishing is a popular pastime in the northern states where the lakes and rivers freeze. The ice fishing houses range in sophistication from a little pup tent to a fully built, functioning home. There are several ways to heat the ice fishing house... Read More »
How to Do a Rough Duct Test
How to Do a Rough Duct Test by Expert Village
Hi! My name is Joshua Lindsey with CFM Building Science Solution. On behalf of Expert Village, we are going to do a duct test in this house. We are doing a rough duct test on this house. Rough duct meaning literally that the house being built is in the... Read More »
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are going to do a duct test in this house. The reason we are setting up another duct blasting, we are going to go ahead and test the duct work again. You... Read More »
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Building & Construction 14 01-18-2010 08:52 PM
blow power of vents mcvane HVAC 5 08-11-2007 04:28 PM
How many heating vents needed per room? AllGoNoShow HVAC 4 01-23-2007 05:06 PM
Screening the crawl space vents ziggy29 Building & Construction 2 11-29-2006 09:26 PM
Floor sealing on balcony over living space absorka Building & Construction 3 11-03-2006 07:36 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
