Closing A Couple Of Registers This Winter. - HVAC - DIY Chatroom Home Improvement Forum
Old 01-07-2013, 11:06 PM   #1
Rewards Points: 45
Closing a couple of registers this winter.
We have one room which is 3 degrees cooler than the rest of our home during the winter. I have closed one small register in the adjacent walk-in-closet, and one small one in the adjacent bathroom to take the edge off in that bedroom. We have an electric HVAC and heat pump with 17 total registers. I understand that closing too many registers can cause damage, but what about 2 out of 17? Thanks for any advice.
Austin83 is offline   Reply With Quote
Old 01-08-2013, 12:25 AM   #2
Rewards Points: 616
i see no real problem..... check t.d. before and after closing..... electric not as fussy as gas......
carmon is offline   Reply With Quote
Old 01-08-2013, 12:29 AM   #3
Rewards Points: 45
Thanks, what is t.d, and how do I check it?
Old 01-08-2013, 12:33 AM   #4
Rewards Points: 616
difference between supply and return air..... use a thermometer.... as I said electric not as fussy....go for it
Old 01-08-2013, 05:55 AM   #5
An old Tradesmen
Rewards Points: 6,544
Probably won't hurt. Would be better off adding another supply to that room, or may be a return.
Old 01-08-2013, 08:33 AM   #6
Amateuralex's Avatar
Rewards Points: 270
Another option is to use a register booster. I used two in a room which is an addition at my house and it made a gigantic difference.
Amateuralex is offline   Reply With Quote
Old 01-08-2013, 08:38 AM   #7
Rewards Points: 6,652
If that one room is 3 degrees cooler than others, I would be looking at return issues, or any leaks through outside wall outlets, along with windows leaking air pass the frames. Even just a section of insulation can cause cool air to radiate off of the drywall.
Old 01-09-2013, 04:51 PM   #8
Rewards Points: 129
I have a similar problem. What do you mean elect. not as fussy as bad. Also when checking supply and return temps what am I looking for?
jeepgrady is online now   Reply With Quote
Ceiling Registers - Insulation vasansrini HVAC 0 01-06-2010 05:41 PM
Storing Canna's for the winter gma2rjc Landscaping & Lawn Care 6 11-14-2009 07:14 AM
Strange Winter Roof Leak Dragon Roofing/Siding 16 10-09-2009 07:06 PM
I can't paint my whole exterior before winter, and I have some exposed wood skiposwald Painting 1 10-15-2008 01:06 AM
couple questions about painting on different surfaces joeyboy Painting 3 08-19-2007 03:33 PM
