-   -   Closing a couple of registers this winter. (http://www.diychatroom.com/f17/closing-couple-registers-winter-168529/)
Austin83 01-07-2013 10:06 PM
We have one room which is 3 degrees cooler than the rest of our home during the winter. I have closed one small register in the adjacent walk-in-closet, and one small one in the adjacent bathroom to take the edge off in that bedroom. We have an electric HVAC and heat pump with 17 total registers. I understand that closing too many registers can cause damage, but what about 2 out of 17? Thanks for any advice.
carmon 01-07-2013 11:25 PM
i see no real problem..... check t.d. before and after closing..... electric not as fussy as gas......:thumbsup:
Austin83 01-07-2013 11:29 PM
Thanks, what is t.d, and how do I check it?
carmon 01-07-2013 11:33 PM
difference between supply and return air..... use a thermometer.... as I said electric not as fussy....go for it:)
beenthere 01-08-2013 04:55 AM
Probably won't hurt. Would be better off adding another supply to that room, or may be a return.
Amateuralex 01-08-2013 07:33 AM
1 Attachment(s)
Another option is to use a register booster. I used two in a room which is an addition at my house and it made a gigantic difference.
gregzoll 01-08-2013 07:38 AM
If that one room is 3 degrees cooler than others, I would be looking at return issues, or any leaks through outside wall outlets, along with windows leaking air pass the frames. Even just a section of insulation can cause cool air to radiate off of the drywall.
jeepgrady 01-09-2013 03:51 PM
I have a similar problem. What do you mean elect. not as fussy as bad. Also when checking supply and return temps what am I looking for?
