Old 02-16-2011, 11:37 AM   #1
Closed off room where central return is located
I enclosed my dining room which has the central return located in that room. The central return is 22x22. I have one door (8x3 foot) with small space below door of about one inch. I will be placing 2 vents of 24x14 in the newly constructed wall. Will this be sufficient for air flow to the air handler or will it be causing the ac unit to stress and cause the coils to freeze. Also, is placement of the vents important as the central return vent is located near the floor as the vents will be about 9 to feet up on the one wall. Should I space the 2 vents apart or does it matter.
markorious is offline   Reply With Quote
Old 02-17-2011, 02:47 AM   #2
HVAC Supermodel
unicursalhex's Avatar
By 24x14 vents you mean pass-throughs so that return will still draw through the room? Probably an ugly solution. I would look into moving the return or adding another
unicursalhex is offline   Reply With Quote
Can portable AC unit intake air from inside room? bludshot HVAC 20 05-13-2010 05:41 AM
return air honola HVAC 11 08-13-2009 08:41 AM
Do I need a HVAC return vent in basement? westing HVAC 12 01-28-2009 01:09 PM
Air return through vented doors yam HVAC 7 08-22-2007 12:37 PM
Supply and Return from Laundry Room bjstewa HVAC 7 03-03-2007 12:39 AM
