Climatemaster Geo System Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 07-31-2011, 07:24 PM   #1
Rewards Points: 242
Climatemaster Geo system thermostat
We are going to install a used Climatemaster 2 stage TT27 unit. I understand the Climatemaster thermostats interact with the unit somewhat to detail fault codes, etc. I would like to know more about that and what exactly they are able to define. Thermocouple temps, delta Ts, faults, run system diagnostic, etc?
Just wanting to figure out if it is worth getting an OEM tstat or not. As long as it is just fault code status, I can just go to the unit if there is an issue. I would anyway. However, if I can glance at temps and system performance, that might be nice to have.
viper is offline   Reply With Quote
Old 07-31-2011, 07:28 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
get a normal heat pump stat.... fault codes should be on the board. Most likely you will know if the unit is acting up.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
looking to update my thermostat, whats compatable with my carrier system detyianni HVAC 11 12-26-2010 11:44 PM
New Heating & AC system takes long time to warm up home poston8 HVAC 10 11-10-2010 03:26 PM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-09-2010 11:58 PM
do I need to use the infinity thermostat with the infinity system or can I use the edge aar HVAC 3 07-07-2010 06:42 PM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 07:48 PM
