Climate Master Cxm/dxm Electronic Heater Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 06-09-2010, 09:12 PM   #1
Rewards Points: 29
Question
Climate master cxm/dxm electronic heater problem
H/V220-240/50/I commerial.
System always display "Fault retry", when restart, beginning runs fine, then "Fault" again, I can heared the fan works, but no wind comes out, no idea...
Ballastar is offline   Reply With Quote
Old 06-10-2010, 06:19 AM   #2
Check if it has a belt drive or direct drive,look at the motor and confirm it's turning. Also check if the coil is clean, the filers are clean and any fire dampers in the duct are open.
A O SMITH gas water heater problem joeyuk Plumbing 62 01-24-2013 11:31 AM
Major gas heater problem.. Questions..Help!! pf76 HVAC 4 01-13-2008 11:01 PM
Water heater problem bear1957 Plumbing 23 11-01-2007 03:53 PM
help to diagnose pilotless heater problem jpplumber HVAC 30 01-02-2007 08:11 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
