Clearance Between Wood Furnace And Propane Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 01-07-2012, 11:17 AM   #1
Question
Clearance between wood furnace and propane furnace
I have a new (last year) 95% efficient propane furnace. I would like to add a wood burning furnace in the basement. How close can the two furnaces be to each other?
I have an existing masonry chimney that I would like to remove and replace with a new masonry chimney (current one has no liner and is leaning at an angle outside). In the basement, it is located right next to my propane furnace. So I know the propane furnace will have to move, but how far away does it have to be? Or does it have to be in a separate room? My basement is pretty much just one big room.
I have seen people mount oil furnaces right next to a wood furnace. But oil is a liquid and doesn't release volatile fumes (or very little). I am worried that if there was a propane leak, it would be ignited by the wood furnace and blow the house up.
bhry is offline   Reply With Quote
Old 01-07-2012, 11:33 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,602
Ayuh,... A gas leak from yer furnace will blow the house Sky High, regardless of the wood stove....
Years ago, We had a wood furnace right next to a gas furnace, just so's we could combine the plenums, 'n use the gas furnace's blower to push the wood heat through out the house...
Old 01-07-2012, 12:06 PM   #3
The installation instructions for the wood stove will have recommended clearances, Personally I like to follow the manufactures recomodations.......
harleyrider is offline   Reply With Quote
Old 01-07-2012, 01:18 PM   #4
MarginallyQualified
Rewards Points: 2,464
I wouldn't want them in the same house
Propane Furnace - Diminishing Gas Supply After Ignition edro HVAC 9 01-13-2012 04:24 PM
chimney liner, excuse for propane furnace upgrade? bubbler HVAC 0 09-16-2011 07:58 AM
Horizontal Venting of Wood Furnace ejfitzpatrick HVAC 2 10-17-2009 06:16 PM
Furnace replacement and conversion from propane to NG. crblog HVAC 2 05-22-2009 03:57 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
