Cleanup After A Compressor Burnout - HVAC - DIY Chatroom Home Improvement Forum
Old 08-23-2009, 07:57 PM   #1
Cleanup after a compressor burnout
This is my first post on this forum, but I have been reading other posts to answer my questions.
I own a small apartment complex and do all of my own work including the air conditioners. One thing I don't understand is how to cleanup a system before installing a new compressor after a burnout.
What is the best way to do it?
Aptguy is offline   Reply With Quote
Old 08-23-2009, 08:06 PM   #2
I should add that I know how to evacuate, pull a vacuum, and charge the system. I'm just concerned with what to use to take care of the acid after a burnout.
Old 08-23-2009, 08:06 PM   #3
GC/Master Plumber/Mech
Rewards Points: 560
Explain to me what you mean by "cleanup a system"
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 08-23-2009, 08:09 PM   #4
I'm not talking about non-condensibles and moisture. But in my reading I find information about "flushing" the condenser and line set. Also, installing a drier with an ability to do something with the acid.
Old 08-23-2009, 08:16 PM   #5
Rewards Points: 560
I understand a burn out. Yes flushing lines, adding a filter/dryer and flushing the coil is right.
But, my advise to you is to hire a pro. Why? Because it will be done right and if done wrong the system will fail because of the acid.
Hang out with the tech and ask tons of questions so that next time you will be able to do the work.
While I'm Plumber/Mechanical I also own 12 rentals and understand the issues with cash flow when it comes to hiring out the work.
You are licensed to handle freon?
Old 08-23-2009, 08:18 PM   #6
Yes, I am licensed and I have spent time with techs, but not concerning this acid question.
Old 08-23-2009, 08:22 PM   #7
Rewards Points: 560
DO you own or have access to a nitrogen tank?
You will need to use nitrogen and lots of it to flush the system.
Give me a minute to find a link for the flush.
Old 08-23-2009, 08:23 PM   #8
I do have nitrogen and know how to use it.
Old 08-23-2009, 08:26 PM   #9
Rewards Points: 560
Here is a like for the flush.
Read the Q & A's it talks about burn outs
When I flush a system I use 1 1/2 tanks of 40 cu tanks
http://www.diversitech.com/literature%5CLIT-FLY-PF.pdf
You can buy this as a kit and then buy refills for the flush.
Old 08-23-2009, 08:27 PM   #10
Thanks a bunch. This is just what I've been looking for.
Old 08-23-2009, 08:28 PM   #11
Rewards Points: 560
Glad to help
What's the Easiest Way to Cleanup After Mowing/Edging? limitdiy Landscaping & Lawn Care 11 08-28-2009 09:00 AM
Clear coat a fence to help with graffiti cleanup? Crytot Painting 2 05-04-2009 12:41 PM
Drywall dust cleanup beer_geek Drywall & Plaster 16 04-07-2009 10:54 AM
simple caulking cleanup question utilitylocator Plumbing 4 02-11-2009 11:13 AM
New drywall project - cleanup question ShawnPA Drywall & Plaster 9 08-25-2008 10:04 PM
