Cleaning Squirrel Cage ? - HVAC - DIY Chatroom Home Improvement Forum
Old 03-13-2012, 10:04 PM   #1
Rewards Points: 216
cleaning squirrel cage ?
how can i clean my squerrel cage ? it is set so i cannot get at it from its opening. seems to me there is some kind of vac attachment or i have to remove the unit from my furnace.
Fix'n it is offline   Reply With Quote
Old 03-13-2012, 10:12 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
To do it properly remove the blower assy. Remove the motor and I wash out using a garden hose. I connect the garden hose to the drain of a water heater so I use hot water but you can use cold water. Wash out is the best. Some guys use compressed air but water does a better job. Just remove the motor
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
The Following User Says Thank You to Plumber101 For This Useful Post:
plummen (03-13-2012)
Old 03-13-2012, 11:10 PM   #3
Rewards Points: 582
yep water is better and the only good and safe way remove blower wheel...
Old 03-13-2012, 11:40 PM   #4
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Before you start banging on the motor shaft going through the squirrel cage loosen the set screw and clean the shaft with some sand paper and spray it down with wd40 or whatever you have on hand.
Then use a small cresent wrench on the flat part of the shaft to spin it while holding the squirrel cage to make sure its lose.
If you need to bang on the end of the shaft use an old 1/4"-5/16" nut driver to bang on with a hammer instead of the shaft.
And make sure to discharge that in-capacitator(capacitor) across both leads with the shaft of a plastic or rubber handled screwdriver while you hold the handle,capacitors normally store between 370-440 volts depending on model.
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
The Following User Says Thank You to plummen For This Useful Post:
ben's plumbing (03-16-2012)
Old 03-14-2012, 10:19 PM   #5
Rewards Points: 216
thanx, guys
Sources on large squirrel cage blower dem455133 HVAC 4 01-20-2012 06:59 PM
grenaded squirrel cage raylo32 HVAC 10 01-18-2012 12:30 AM
Help wiring squirrel cage fan qoncept HVAC 2 07-14-2011 09:22 AM
Blower squirrel cage Dbenzboy HVAC 4 08-27-2010 09:05 PM
Squirrel cage motor in air handler...no start andyinrichmond HVAC 13 03-15-2009 04:53 PM
