Old 04-24-2006, 11:16 PM   #1
Cleaning an evaporator on A/C system
In our house that we just moved into the ac does not work all that good.I noticed that the people that lived here before installed the wrong size filter.
I work on automobile ac systems so I pretty much know what that will do to a system.
I am wondering,When they build these ac and furnace type systems do they make the evaporator's pretty easy to get to?
Thanks Doug
Doug Crf is offline   Reply With Quote
Old 05-07-2006, 10:10 AM   #2
coolmen's Avatar
Should be a front panel held by 1/4" screws. this will access the top side of the coil.you may have to get around the flue chimny if it in the way.
coolmen is offline   Reply With Quote
Water Purification System - Maintenance Qs cjcocn Plumbing 1 11-18-2008 08:31 AM
Zone system not working with heat. deliriousga HVAC 5 12-29-2006 07:04 PM
Size A/C system properly 70stang HVAC 1 03-26-2006 08:22 PM
Replace furnace, coil and duct system sps123 HVAC 2 01-07-2006 11:56 AM
