Clean Evaporator Coil - HVAC - DIY Chatroom Home Improvement Forum
Old 04-27-2014, 02:52 PM   #1
Rewards Points: 85
clean evaporator coil
At the end of last Summer I noticed some water coming out from under the furnace. I opened it up and saw that the drain hose was plugged up. I got a new hose and put in new 1" pvc, plus a pvc trap as I quickly learned that without a trap the hose sucked air into the furnace, thus, no draining. After installing the trap there was still a bit of water coming from under the furnace so I found out that the coil fins were a bit dirty. I cleaned them with two cans of cleaner but now wish to do it again before a/c season. What is a good product to use and what is the best procedure?
boilermaker27 is offline   Reply With Quote
Old 04-27-2014, 05:28 PM   #2
An old Tradesmen
Rewards Points: 6,060
Non rinse evap cleaner.
Best procedure varies with each coil, as they aren't all installed the same.
Old 05-21-2014, 02:04 AM   #3
airtrackinc's Avatar
Rewards Points: 78
Its call: form Evap cleaner you can check with your heating cooling contractor
airtrackinc is offline   Reply With Quote
Tile never clean Shawn8 Tiling, ceramics, marble 8 01-28-2014 07:05 AM
Clean out vs floor drain zubor Plumbing 2 10-25-2012 09:19 PM
Best way to clean up metal cap with build up dirt? Andee77 Painting 1 07-27-2012 10:19 PM
Looking for ideas...drywalling a clean out MLayden Drywall & Plaster 1 06-15-2012 12:14 PM
How often do you clean your Paslodes Bearcreek Tools 1 08-24-2009 10:00 AM
