Old 12-06-2006, 08:02 AM   #1
Clean Duct System?
I have a 30 year old home heated by a forced hot air system. My duct system has never been cleaned but I have heard that it is usually not necessary to do so unless you know there are rodents, etc in there. What are your thoughts? (I have always had a furnace filter in place & the whole system runs rarely as my coal stove pretty much warms the whole house unless the temp dips below 20 degrees)
Devil505 is offline   Reply With Quote
Old 12-06-2006, 11:54 AM   #2
Clean Duct System?
Do you use the better quality filters or the .99 cent ones?
How often do you change the filters
redline is offline   Reply With Quote
Old 12-06-2006, 06:15 PM   #3
Clean Duct System?
They still have air in them and air hold dirt. Absolutly have them cleaned.
acefurnacefixer is offline   Reply With Quote
Old 12-06-2006, 07:22 PM   #4
Clean Duct System?
I use the cheap filters
Old 12-06-2006, 07:40 PM   #5
Clean Duct System?
Another GOOD reason to have them cleaned
Old 12-06-2006, 08:30 PM   #6
Clean Duct System?
It is better to buy the more expensive ones ($3-6) when they go on sale. Stock up.
The better filters stop more dust, the furnace will stay cleaner, the furnace will operate more efficiently and the occupants will have less allergies.
Old 12-06-2006, 09:31 PM   #7
Clean Duct System?
Come on man, read the post...........that alone is plenty enough reason to clean the ducts.I dont care if they have a space shuttle quality filter in place............after 30 years YOU NEED YOUR DUCTS CLEANED !
Old 12-07-2006, 07:02 AM   #8
Clean Duct System?
I was looking for opinions acefurnacefixer as many others, including the US EPA say it is not necessary. Here is an excerpt from an EPA report :
......."Knowledge about the potential benefits and possible problems of air duct cleaning is limited. Since conditions in every home are different, it is impossible to generalize about whether or not air duct cleaning in your home would be beneficial."....
Another excerpt:
..."If no one in your household suffers from allergies or unexplained symptoms or illnesses and if, after a visual inspection of the inside of the ducts, you see no indication that your air ducts are contaminated with large deposits of dust or mold (no musty odor or visible mold growth), having your air ducts cleaned is probably unnecessary. "
A third excerpt:
.......".if a service provider fails to follow proper duct cleaning procedures, duct cleaning can cause indoor air problems. For example, an inadequate vacuum collection system can release more dust, dirt, and other contaminants than if you had left the ducts alone. A careless or inadequately trained service provider can damage your ducts or heating and cooling system, possibly increasing your heating and air conditioning costs or forcing you to undertake difficult and costly repairs or replacements."
I have looked into the 6" supply pipe I cut & find no large deposits that aren't simply blown out when the furnace kicks on at the begining of the heating season.
The full EPA report is here:http://www.pueblo.gsa.gov/cic_text/h...s/airduct.html
Old 12-07-2006, 09:25 AM   #9
Thoroughbred Mopar Man
Clean Duct System?
Hi Devil505
The company I work for actually does duct cleaning. Most often the reason for cleaning duct in this area is due to mold and dust mite accumulation. But unless the duct work has piles of stuff lying in the bottom, alot of times it may not be needed. You can add in UV light kits and install a good pleated filter as redline suggested. This will usually help stop most problems. The biggest draw back to a UV bulb system is the maintenance cost, but that is going to be the case with anything that purifys air. Let me know if you need any further information.
Good luck
Rusty
#CARRIERMAN is offline   Reply With Quote
Old 12-07-2006, 09:33 PM   #10
747
registered
747's Avatar
Clean Duct System?
If i had a forced air furnace the first thing i would do is have a hvac guy mount one of those electric airfilters on the side which zap dust. Then you just pull it out once a month run it through the diswasher. Or at least you can if its the american standard one.
747 is offline   Reply With Quote
More On This Topic
Someone has said duct tape is like The Force (from Star Wars) because it has a dark side and a light side and holds everything together. Some people have taken duct tape out of the "holding things together" business and into fashion. People make all... Read More »
Not only is mold unsightly, it can cause health problems. Mold grows in humid or damp areas of your house and will continue to grow unless removed. After removing the mold, you can prevent it from growing back with a few simple steps. Here are a few tips... Read More »
Due to the potential for high lead content, you must take extra care to dispose of car coolants and antifreeze products properly. First, you must determine whether or not the coolants you want to dispose of are considered hazardous waste due to lead... Read More »
Creating delicious meals for the family at home also creates tantalizing aromas in the air. However, you need proper air ventilation to remove odors from grease, smoke and moisture. Whether you're redoing your kitchen or building a new home, several... Read More »
How to Clean Inside Irons
How to Clean Inside Irons by Expert Village
Hi, I'm Marti on behalf of expertvillage.com and we are going to talk about how to clean your iron. What you want is white vinegar straight white vinegar your going to put it in towards your reservoir chamber. I'm going to fill it up pretty much cause we... Read More »
Condensation in Wall: Can I Seal a Dryer Duct With Caulk? xquercus HVAC 5 07-01-2007 03:33 PM
1000-1400cfm...duct sizing Swordfish215 HVAC 1 01-15-2007 04:22 PM
Can I use duct tape? Dusty HVAC 2 09-27-2006 09:28 PM
Size A/C system properly 70stang HVAC 1 03-26-2006 08:22 PM
Replace furnace, coil and duct system sps123 HVAC 2 01-07-2006 11:56 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
