Clayton Woodburner Wiring - HVAC - DIY Chatroom Home Improvement Forum
Old 10-20-2012, 10:27 PM   #1
twk
Clayton woodburner wiring
I recently purchase a used Clayton woodburning furnace. I need a wiring schematic but so far everyone I received from US Stove is for wiring a Honeywell. Ths furnace is a model 7.1 and doesnt have honeywell equipment. It has a printed circuit board with 3 connectors The top connector has two wires which go to the draft blower; the middle connectoris for power to the circuit board. the third connector has 4 wires, black blue red and white. I need to know how to connect these to run a 3 speed blower. If someone has a Clayton woodburner with a circuit board your help would be greatly appreciated.
twk is offline   Reply With Quote
Old 10-21-2012, 07:57 AM   #2
AKA HVACTECHFW
Rewards Points: 1,208
Here is the parts page for a clayton 7.1, it does not show any PCB. It does show a limit kit and that is the only thing even close to what you are talking about. I think someone may have changed the wiring and pcb on your furnace. DO you have a picture?
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 10-21-2012, 09:31 AM   #3
twk
I'll get one.
Old 10-21-2012, 05:56 PM   #4
twk
Attached is the photo of the circuit board
Old 10-21-2012, 11:28 PM   #5
AKA HVACTECHFW
I see nothing like that available for your model. Is there a schematic on the back of the plate/door that went over the PCB?
IT IS WHAT IT IS
Old 10-22-2012, 04:36 PM   #6
twk
No, the party i purchased it from couldn't locate it. If this is any help, in addition to 7.1V it also shows 5.6V on the metal information plate.
Old 10-22-2012, 05:22 PM   #7
AKA HVACTECHFW
What are your connections on the blower?
Typically
Black = high speed
Blue = med speed
red = low speed
white = neutral
IT IS WHAT IT IS
Old 10-24-2012, 07:30 PM   #8
twk
Those colors are correct.
Old 10-24-2012, 07:44 PM   #9
AKA HVACTECHFW
can you find ANY numbers on the circuit board?
IT IS WHAT IT IS
Old 10-25-2012, 04:52 PM   #10
twk
Yes, on the front it says Clayton Micro Trak Marketing. The back says TKH p/n 10927.
Old 10-25-2012, 06:30 PM   #11
AKA HVACTECHFW
I still can not find anything. you will need to call US stove.
IT IS WHAT IT IS
Old 10-26-2012, 05:44 PM   #12
twk
I appreciate your help and the time you've put in.
Old 12-17-2012, 09:59 PM   #13
Wiring is correct
I bought the Clayton Stove (used) a few years ago and have the same board that you do. mine was working up until one of the connectors shorted out.
I'm not an electrician, but when the stove is running, there is power from the black (hot wire) going to the board. Once the box gets up to temp, one of the colored wires on the four prong connector goes hot, and the rear blower motor kicks on.
Please let me know if you need any more specific info....
Dave
DavePts is offline   Reply With Quote
Help with wiring issues on a newly purchased house ThatGuy Electrical 13 01-17-2012 10:51 AM
Attic wiring - ceiling lighting uses 14/2 cable without ground darlingm Electrical 3 11-29-2011 09:01 AM
Backyard wiring questions MikeInDetroit Electrical 1 11-02-2011 09:46 AM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 06:45 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
