Clare CHU 072 NH3A Problum - HVAC - DIY Chatroom Home Improvement Forum
Old 09-23-2013, 07:56 AM   #1
Question
Clare CHU 072 NH3A problum
I have a Clare model # CHU 072 NH3A Natural gas furnace that has run mostly problem free for the last few years. Last winter the furnace would cycle but no "whoosh" and no heat. Called repairman and they changed a "vacuum pod looking thing in the front and away we went. Worked great all winter. Then in the summer we used the central air with no issues. Tried to turn on the heat this fall and again it is cycling with no start up and no heat. Any Ideas?? thanks.
shawnf is offline   Reply With Quote
Old 09-23-2013, 04:17 PM   #2
An old Tradesmen
Rewards Points: 7,414
Check to see if the vacuum pod(pressure switch) is closing.
The Following User Says Thank You to beenthere For This Useful Post:
shawnf (09-23-2013)
Old 09-24-2013, 09:56 AM   #3
yes it makes a clicking sound when you apply vacuum or blow you here a click sound and a click sound comes from somewhere inside near the upper part of the furnace. But still no whoosh sound or heat. Thanks anyways.
Old 09-24-2013, 05:13 PM   #4
An old Tradesmen
Does the HSI glow.
Clare furnace won't start long3817 HVAC 7 01-12-2012 05:11 PM
clare furnace needs reset to start dustin020 HVAC 2 10-15-2009 06:06 PM
