Clanking Rheem Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 12-16-2010, 10:09 PM   #1
Just moved into a house with a Rheem furnace. It was cleared by a private inspector and the local gas company. It makes an intermittant clanking sound when it's on. Seems to go off when the flame goes out and the blower is just on. The clank is pretty anoying. Is this normal for a Rheem?
Wbraun is offline   Reply With Quote
Old 12-17-2010, 01:50 AM   #2
Look at the blower wheel (best to pull the entire housing so you see all the way is blower wheel) there may be a piece of paper or other material striking the wheel.
hvaclover is offline   Reply With Quote
Old 12-17-2010, 05:36 AM   #3
Rewards Points: 516
Also, motor bearings need oil each season. Had a furnace blower wheel on shaft years back and boy, did it makes noise from lack of maintenance.
diyorpay is offline   Reply With Quote
Old 12-17-2010, 06:01 AM   #4
Rewards Points: 1,766
"...motor bearings need oil each season..."
I think most motors have sealed bearings in recent times but can't hurt to look for an oiling port.
bob22 is offline   Reply With Quote
Old 12-17-2010, 11:33 AM   #5
Very correct. Motor of today are non-oilable.
Because of the intermittently nature of the noise I would think it more likely to be something stuck in the blower wheel like paper or some such.
The only other thing might be the blower wheel collar is loose or some of the blower vanes are coming loose.
Problem with Rheem Criterion Furnace sweetsue777 HVAC 3 03-10-2012 11:13 AM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Rheem 80% furnace 3rdroofdown HVAC 2 11-23-2009 08:59 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
