Circulator Runs All The Time - HVAC - DIY Chatroom Home Improvement Forum
Old 02-05-2011, 06:42 PM   #1
circulator runs all the time
I replaced my honeywell aquastat no. R8182D controller on my oil burner just recently, i then noticed the circulator was running all the time, maybe unrelated to the new aquastat and maybe its been doing it for some time.
the boiler runs up to temp. and shuts down normally. but the circulator never shuts off. closed all the thermostats and it still runs. disconnect the thermostat wires from the aquastat and it shuts down. checked across those 2 wires and i get nothing, check to ground and i get single digit voltages. might i have a short in 1 of the thermostats? I get 26v across the transformer end. should ther be no voltage at the aquastat thermostat wires even with all the thermostats closed. im talking about that small voltage to ground stuff i mentioned.
Fetts is offline   Reply With Quote
Old 02-05-2011, 07:01 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
which terminals do you have the circ connected to?
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 02-05-2011, 08:39 PM   #3
C1 and C2 Just like on the old aquastat. Thanks for the reply!!
Old 02-05-2011, 10:52 PM   #4
KCA
Some systems have a toggle switch for the circulator that says constant & auto. What boiler do you have?
:-) Ken
KCA is offline   Reply With Quote
Old 02-06-2011, 05:20 AM   #5
An old Tradesmen
Rewards Points: 6,548
If it stops running when you disconnect the thermostat wires. The problem isn't the aquastat.
How many thermostats do you have, and do they all connect directly to the aquastat?
Old 02-06-2011, 03:05 PM   #6
My boiler is a utica, and i have 4 zone valves only 1 wire connects to the aquastat thats at the end of the loop. so yes they are all connected. thanks for the input!
Old 02-06-2011, 03:10 PM   #7
another thing i want to mention is that all i changed was the aquastat, i never touched anything else. maybe this has been going on for some time and i didnt notice.
Old 02-06-2011, 05:49 PM   #8
An old Tradesmen
Probably one of thy zone valves has a bad end switch.
Old 02-06-2011, 06:25 PM   #9
Yea ill check them out, one other question with all the thermostats off should there be absolute o voltage to the aquastat? Thanks
Old 02-06-2011, 08:46 PM   #10
An old Tradesmen
The aquastat has its own 24 volts.
The end switches of the zones valves have to be checked with their wires disconnected from the aquastat.
What brand zones valve do you have.
Old 02-06-2011, 09:05 PM   #11
Taco , Thanks
Old 02-06-2011, 09:07 PM   #12
Could you tell me how to check an end switch? Thanks!
Old 02-06-2011, 09:17 PM   #13
An old Tradesmen
The end switch of a Taco. Is the number 2 and 3 terminal. You will get some voltage back to the aquastat with that zone valve. usually less then 10 volts.
On those zone valves. Remove the wires from terminals 2 and 3. Then check for continuity. If it has continuity, the end switch is closed. And probably the valve is partly open. Meaning the power head needs replaced.
Old 02-08-2011, 12:22 PM   #14
Thanks for all the Help! Did like you said with the end switch and yes 1 of my 4 zone valves was bad. replaced it and everythings good!!
Polyurethane Curing Time? 1simple Flooring 2 01-03-2011 07:11 PM
Cycle time Yoyizit HVAC 2 06-29-2009 08:10 PM
Can I grout a little at a time? yummy mummy Tiling, ceramics, marble 5 06-16-2009 02:21 PM
DIY tiling first time? SeraSmith General DIY Discussions 8 04-04-2009 02:19 PM
Sump Pump cycles 3-8 times each time it runs Delegator Plumbing 2 04-06-2008 01:48 PM
