Circulator Pump..please Help...it's Cold Here! - HVAC - DIY Chatroom Home Improvement Forum
Old 12-16-2010, 09:12 PM   #1
circulator pump..please help...it's cold here!
Thank you all in advance for your help. I have a question about installing a circulator pump for a hydronic boiler system. My pump is bad (bearing is shot). Anyway, I wanted to make sure I put the pump pumping the right direction. The arrows on my pump point down (like it's pumping into the boiler). I didn't think this was very common, but maybe my system is older? Its a Well-Mclain. My pump is on the left side of the boiler. The arrows on the Grundfos pump are pointing down. Anyway my question is are the arrows correctly indicating that my pump should be pumping down? Thank you so much for your time--it's cold here!
matt teo is offline   Reply With Quote
Old 12-16-2010, 09:19 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
you should have 2 pipes from your boiler, one supply and one return. Supply is the higher of the two and return lower. so..... on supply side arrow away from boiler...... on return side arrow towards boiler
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
The Following User Says Thank You to hvactech126 For This Useful Post:
matt teo (12-16-2010)
Old 12-17-2010, 07:03 AM   #3
Rewards Points: 1,216
The pump arrows should be pointing toward the heater and that should be the return hot water side.
Sorry already mentioned in previous post.
COLDIRON is offline   Reply With Quote
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 08:17 PM
Hot Water Turning Cold - Could it be the washer/dryer? kissiffer4 Plumbing 3 01-28-2010 04:47 PM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 06:59 AM
No Cold Water at all - both cold and hot pipes are burning to the touch bluecifer Plumbing 12 01-19-2009 10:29 AM
Help with low pressure cold water upstairs lewissv Plumbing 5 01-26-2007 08:05 AM
