Circulator On Oil Fired Boiler - HVAC - DIY Chatroom Home Improvement Forum
Old 02-24-2010, 06:55 PM   #1
circulator on oil fired boiler
hi! i have a hot water baseboard weil-mclain oil fired boiler about 20 years old,i noticed for some time now that my circulator will come on for a few minutes before and burner comes on,but never does the circulator pump stay on after the burner shuts off as it should and like it did in past,could this be in the temperature gauge.i also get my hot water from the boiler as well.thanks for any help. bill
bazz is offline   Reply With Quote
Old 02-24-2010, 08:18 PM   #2
Licensed Master Plumber
The thermostat calls the relay that runs the circulator. When the temperature drops below the set point of the aquastat the burner then runs. Domestic hot water is controlled by the low limit aquastat which maintains it's set point ( usually about 160 ) Unless it's not heating or you are not getting enough hot water it's operating fine.
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
Digital Tstat w/ oil fired boiler flatlander745 HVAC 6 01-07-2010 06:59 PM
circulating pump install for wood fired outside boiler tiltd General DIY Discussions 2 08-27-2009 12:45 PM
Please help me stop my oil fired boiler from banging at the end of each cycle! snanancekivell HVAC 6 01-13-2009 05:12 PM
Oil fired boiler need help with gustavus HVAC 4 11-30-2008 05:41 AM
