Circulation Pump Innop - HVAC - DIY Chatroom Home Improvement Forum
Old 01-23-2011, 02:40 PM   #1
circulation pump innop
we have little to no heat circulation pump not running burner is running and getting up to temp no power to pump. possible bad aquastat? any way to repair or anything else that could cause problem
cwhitn6 is offline   Reply With Quote
Old 01-23-2011, 03:40 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,380
Ayuh,... Have you tested for power at the pump,..??
I would guess the aquastat, or the pump itself,...
You could hard wire jumper the pump to run to get through the night I suppose...
Bondo is online now   Reply With Quote
Old 01-23-2011, 05:27 PM   #3
I have checked pw there is none at pump. I put a temp. Jumper and pump is working great suspect aquastat is bad
Old 01-24-2011, 10:22 AM   #4
Bondo's Avatar
Ayuh,... I agree...
Old 01-24-2011, 03:43 PM   #5
Thanks now I need to find one cheep cheep! $125 plus shiping cheepest so far anyone have one used honeywell L8148A????
Sump Pump Questions henlij Plumbing 22 03-16-2015 10:00 PM
Circulation pump on boiler uncleneiler Plumbing 4 06-22-2010 09:01 AM
Well Pump Problems dannyjoe Plumbing 6 10-01-2009 06:10 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
Help Needed ... turn on circulation pump when furnace in AC mode? Diranged HVAC 12 06-04-2009 06:33 AM
