Circulating Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 03-06-2006, 07:40 AM   #1
tpm
Rewards Points: 14
Question
Circulating problem
I have a oil fired boiler with baseboard heating. The boiler has 4 zones and I notice that the main floor zone takes a very long time to heat. the baseboard is not as hot as the other zones so I'm thinking maybe the circulator pump may be faulty. the unit is in very good condition as it is only no more then 5 years old. everything was changed. I'm running taco circulator pumps. What would I check first?? Thanks
tpm is offline   Reply With Quote
Old 03-09-2006, 11:27 AM   #2
Contractor
tgeb's Avatar
Lightbulb
some ideas
This is not exactly my field, but...
I would first check to be sure you are getting power to the zone motor with a volt meter, then...
I would switch out the pump motor for the zone running cool with one that you know is working properly. If that corrects the problem on that floor, replace the zone circulator motor.
You may also have some flow check valves that could be sticking.
Tom
Tom
www.gebcon.com
tgeb is offline   Reply With Quote
furnace problem captjack HVAC 8 11-23-2007 12:15 PM
Trouble installing ceiling light fixtures: same problem x3 sweetroad9 Electrical 5 04-13-2007 02:46 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
A/C Thermostat Problem therumblefish HVAC 7 11-01-2006 09:08 PM
Drywall, Mold Problem due to Leaked Water june03 Building & Construction 2 10-31-2006 08:24 AM
