Circuit Board Failure Due To High Voltage - HVAC - DIY Chatroom Home Improvement Forum
Old 01-06-2012, 07:07 PM   #1
Circuit Board Failure due to High Voltage
Hopefully a quick question. My Lennox 80UHG furnace recently stopped working. I diagnosed the problem as a shot circuit board (12L6901 replacing with 83M00). When checking the voltage, I noticed that the home voltage seemed high. The line voltage is 127 Volts resulting in a voltage output from the transformer of 27 Volts (vs. 24 Volt spec). In order to avoid going through this problem again, does anyone know if these circuit board specs allow for a voltage that high?
Thanks,
Steve
huyer is offline   Reply With Quote
Old 01-06-2012, 07:29 PM   #2
Not a problem.
The Following User Says Thank You to Marty S. For This Useful Post:
plummen (01-06-2012)
Old 01-06-2012, 07:31 PM   #3
MarginallyQualified
Rewards Points: 2,464
Originally Posted by huyer View Post
The line voltage is 127 Volts...
Line voltages fluctuate all the time.
Occasionally a real spike can come through but 127VAC isn't that.
While 127VAC is at the upper limit of normal service range (5-6% +/-) and within the normal incidental range (10%+/-) even at steady rate it is within the reasonable tolerances that can ordinarily be expected and which your controls should be able to tolerate.
Old 01-06-2012, 08:26 PM   #4
Thanks a lot
Thanks for the infor guys, I really appreciate it.
Steve
Old 01-06-2012, 09:53 PM   #5
REP
Almost all electrical items in this country operate with a 10% limit.
!20 volt motors will operate at 108V or at 132V. 24V items at 21.6V or at 26.4V and so on.Its built into the national electric code.
REP is offline   Reply With Quote
Old 01-07-2012, 06:07 AM   #6
An old Tradesmen
Rewards Points: 6,112
The low voltage devices of a typical furnace, A/C, or heat pump, are rated to work with a voltage as high as 30 volts.
Need Bryant Plus 80 Circuit Board tbzep HVAC 3 12-30-2010 01:14 AM
circuit board repair for pellet stove mudmusic8 Electrical 4 06-03-2010 11:08 PM
cord to my heating pad got ripped out from its circuit board..any help? flashme18 Electrical 8 07-09-2008 11:28 PM
Inducer fan assembly or inducer control circuit board failing realblonde94526 HVAC 3 05-12-2008 08:28 PM
Low voltage in same box as high voltage? mpedrummer Electrical 2 02-28-2007 12:49 PM
