Old 10-13-2009, 08:04 PM   #1
Default Cigarette smoke coming through return?
Ok, forgive me if I am using the wrong terminology; what I believe is my central air "return" vent (mounted on the second floor of my condo) appears to be allowing smoke into my condo, coming from my neighbor. Is there any way I can put some kind of odor blocking/absorbing filter in there to block the smoke? Just to be clear, I am not referring to my furnace/furnace filter. Thanks.
diyGK is offline   Reply With Quote
Old 10-13-2009, 08:09 PM   #2
old pro
THe only filter that blocks smoke is a carbon type and they are rare and hard to find and don't last long. Some buildings have a central exhaust for the hallways and building. I would talk to the landlord and see if anything can be done. If you interfere with it they can blame you. Does your building have no smoking rules, you should not have to put up with others smoke, talk to the landlord about it.
Old 10-13-2009, 08:16 PM   #3
It's not a building. It's a row of condo's, which resembles what people consider townhouses, so there is no landlord. We are all responsible for our own central air units (each condo unit has its own central air unit). So I kinda on my own here. So far my only solution is to block the return, which is fine until I need to turn on the heat.
EDIT: would I damage anything if I cut some kind of carbon filter and taped it to the inside of the return grille?
Old 10-13-2009, 08:23 PM   #4
old pro
Your ducts should not be linked to the neighbors for fire separation/hazard/code issues. Not sure why his smoke would go to you unless you have a negative pressure and his is positive. Carbon filters plug easily and can restrict airflow and overheat the furnace. I would get a experienced servicetech to find out what is going on.
Old 10-29-2009, 08:28 AM   #5
I made a little bit of progress. I insulated the celing where our basements are split ( we each have half of the basement) and there's less smoke down there. I still have the problem upstairs however and I'm wondering if its coming from the kitchen stove exhaust, maybe the neigbors are using it to exhaust the smoke and its exhausting into my place? (his would be directly below mine).
Old 10-29-2009, 01:19 PM   #6
An old Tradesmen
If your getting smoke from another condo. Then it is a condo association problem.
It is also a fire code problem.
More On This Topic
I'm Sylva Kelegian with Expert Village and I'm here with Simone Luncher from Pet Mania in Burbank. We adopt a lot of cats and dogs out and we always do home checks and we always ask the people who adopt the dogs or the cats to check with their landlord... Read More »
A few things to have in the house for fire safety would be a smoke detector for at least each room. You need a fire extinguisher in the kitchen and the garage. A carbon monoxide detector where you might have any gas appliances, whether it be by the... Read More »
If you've made a decision to invest in rental property, consider buying a condominium. Condos are desirable rentals in a number of settings and for a number of reasons, from the vacation condo in the mountains or at the beach, to the city condo with... Read More »
A rental property is a great way to supplement your income. You not only get the rental fees each month, you also get the equity that is building in your property. But being a landlord isn't easy. You're responsible for maintenance on each rental... Read More »
On behalf of Expert Village, this is Dan Kelly with Keller Williams Realty here in Miami Shores, Florida. I'm with the Kelly White Team, and today we're going to tell you how to buy a house. In this area that I deal with as a realtor, we have single... Read More »
Wiring Smoke Detectors - Has to be straight run? WaldenL Electrical 15 08-30-2009 11:22 AM
Cigarette Smoke digitap HVAC 9 05-26-2009 10:57 AM
How do you stop cigarette smoke coming through walls? ACTed General Discussion 3 01-19-2009 07:28 PM
help -black smoke coming out of chimney after furnace service schmolze HVAC 9 11-14-2008 06:54 PM
add vent/move cold air return CamL HVAC 0 03-22-2008 10:45 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
