Cigarette Smoke Coming In From Outside Through HVAC Return? - HVAC - Page 4 - DIY Chatroom Home Improvement Forum
Old 07-30-2011, 08:12 PM   #46
biggles's Avatar
the furnace does pull air in from any place around that that penetration on the outside wall the closet has to be the total return with those sheet rock mounted grills.SUB you need to run the supply fan only to see if you get the smell first with the brown doors closed as usual the again next smoke out with them open
Old 07-30-2011, 08:35 PM   #47
I crap rainbows.
Sublimesub's Avatar
Send a message via AIM to Sublimesub Send a message via Yahoo to Sublimesub
Well, perhaps the smoke smell is coming from the neighbor's apartment instead?
Do you mean the folding closet door?
Sublimesub is offline   Reply With Quote
Old 07-30-2011, 08:58 PM   #48
Hvac Pro
yuri's Avatar
Rewards Points: 396
Originally Posted by Sublimesub View Post
LOL What does that mean I should do? Sorry, I'm such a n00b, I have no idea what any of that means. -.-
I cannot explain it any clearer but if you know a handyperson who can do some carpentry or call a HVAC tech and have them read my post it should be fairly straightforward.
Good Luck
Old 07-30-2011, 09:03 PM   #49
I crap rainbows.
Sublimesub's Avatar
There is information stuck to the unit with the company that installed it's info. I'll call them. If I understand correctly (I'm really trying!) it sounds like a seal is broken, and to fix my problem, it just needs to be sealed with silicone? Either way, thank you VERY much, and I'm soooo looking forward to getting this fixed!
Old 07-30-2011, 09:05 PM   #50
I crap rainbows.
Sublimesub's Avatar
Oh. I totally missed this part of your post, at the bottom: "You need to get it resealed outside and possibly inside with whatever method they originally used. Silicone won't stick to mastic and vice versa."
Got it! Thanks again
Old 07-31-2011, 05:52 AM   #51
biggles's Avatar
yes the folding doors if you leave them open with just the fan on and the smoking going on that might limit the air being drawn into the closet from the outside thru the leaks on that outter wall the condenser grills go thru..good luck
How do you stop cigarette smoke coming through walls? ACTed General DIY Discussions 6 08-16-2011 03:14 PM
Wiring Smoke Detectors - Has to be straight run? WaldenL Electrical 15 08-30-2009 09:22 AM
Why is water coming out from the bottom of the HVAC unit? Woz HVAC 11 08-02-2009 08:38 AM
Cigarette Smoke digitap HVAC 9 05-26-2009 08:57 AM
help -black smoke coming out of chimney after furnace service wombosi HVAC 9 11-14-2008 04:54 PM
