Choices Are Trane Or Carrier - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-16-2013, 09:31 AM   #16
Rewards Points: 2,038
still wondering about the noise from a Trane, but I'm "assuming" that a company that makes AC's for residential would know homeowners don't want a loud racket when the AC runs so I guess I'll take my chances......
Startingover is offline   Reply With Quote
Old 02-16-2013, 10:04 AM   #17
An old Tradesmen
Rewards Points: 6,074
I believe Lennox currently has the quietest rate condensers.
The Following User Says Thank You to beenthere For This Useful Post:
Startingover (02-16-2013)
Old 02-16-2013, 10:17 AM   #18
I've always heard Lennox are good but I figured they'd cost too much so I didn't even price them. Maybe it wouldn't hurt to get an estimate and since this Co can install any kind and they've already been to my house they wouldn't have to come here again. I'll call them Monday. Thanks for the idea.
If they're just a couple of hundred more I could swing it but if it's more I'll stick with the Trane.
Old 02-16-2013, 02:00 PM   #19
Cruising into the sunset
JulieMor's Avatar
Rewards Points: 518
Typically, return air is installed in every room with a supply except bathrooms and kitchens. If you can get one in your BR, do it. If they run the duct in your attic, make sure it's insulated.
JulieMor is offline   Reply With Quote
The Following User Says Thank You to JulieMor For This Useful Post:
Old 02-16-2013, 02:27 PM   #20
An old Tradesmen
Its best to get quotes from different contractors. First, one may have better ideas then the next. Second, while one may be able to gt any brand and install it, they won't get the other brands for the same price as a dealer for that brand.
I can get Lennox equipment, but not as cheap as a Lennox dealer that sells 150 units a year.
The Following 2 Users Say Thank You to beenthere For This Useful Post:
hvactech126 (02-16-2013), Startingover (02-16-2013)
Old 02-16-2013, 03:17 PM   #21
thanks, also I'll ask if they will be able to get repair parts down the road.
The Following User Says Thank You to Startingover For This Useful Post:
Old 02-16-2013, 06:39 PM   #22
Missouri Bound's Avatar
Originally Posted by beenthere View Post
If you currently have a 2 ton and it does a good job, no reason to increase size.
Wow.. somebody agrees with me on that. So many times I hear that you MUST have a manual J when replacing units, but I have said all along that if the existing unit has done it's job, no reason to recalculate the sizing.
Do you want it your way or the right way?
The Following User Says Thank You to Missouri Bound For This Useful Post:
Old 02-16-2013, 07:07 PM   #23
An old Tradesmen
Its very possible that he only needs a 1.5 ton unit. Slowing the blow on a 2 ton can get him down to 1.5 tons.
If it was a 3 ton. Then I would have said something like get a load calc, maybe you don't even need a 3 ton, let alone a larger unit.
Humidifier for Carrier Infinity 96 system rvmeush HVAC 1 09-19-2012 07:16 AM
Compare Carrier Model 25HNA936A003 versus Model 25HPA636 gchapman General DIY Discussions 0 11-02-2010 01:52 PM
lennox vs trane vs carrier oldfartswife HVAC 62 10-09-2009 06:23 PM
Product Advice - Trane or Carrier 99Problems HVAC 5 05-28-2009 07:23 PM
Trane Carrier XL80 fan runs constantly when switch is on jheavner HVAC 13 10-25-2008 10:54 PM
