Choices Are Trane Or Carrier - HVAC - DIY Chatroom Home Improvement Forum
Old 02-13-2013, 02:35 PM   #1
Rewards Points: 2,154
choices are Trane or Carrier
13 seer, and probably 2 ton.
I'm getting estimate tomorrow to replace my 10 condenser & 16 yr old air handler. Which would you go with?
I'm leaning towards a Trane but not sure why.
PS
They can install any brand I want. They just carry Trane and Carrier. Also Rheen/Rudd are suppose to be a good brands, right?
Startingover is offline   Reply With Quote
Old 02-13-2013, 02:59 PM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by Startingover View Post
I'm getting estimate tomorrow to replace my (heat pump system)
How many estimates are you getting? I hope more than one.
Less concern here about limiting the brand choice...
than that you're choosing the contractors well.
The Following User Says Thank You to TarheelTerp For This Useful Post:
Startingover (02-13-2013)
Old 02-13-2013, 04:01 PM   #3
It's been tough to get any recommendations. I called my electrician, an older man, and he gave me 2 names.
I had someone come out that was recommended but the guy was 72 and doesn't work anymore. He had health issues. He turned his license over to his son, who had a stroke and can only use one arm. I didn't feel confident of future service. The dad had a good rep at one time but who knows about the son.
I joined Angies List and wasted my 10 bucks. Hardly anything for this area.
I called the phone # of the Co. who installed the existing unit, (which leaks) and they didn't address the leak which was my main concern. The 72 yo said that older units had metal trays which sometimes rust and leak but now the pans or trays are plastic. That made sense.
I have one other phone # that I will try. My elec. said this company coming tomorrow is good but theres another guy who would do a good job, so I'm getting prices from both.
From what I've been told it's $4,000 for a 13 seer for my house.
Another thing the elderly man said was that he'd put a 2.5 ton unit in my house (1,430 sf) and if I ever wanted to make the big double garage into a room I could. (I live alone and would never do that.)
Old 02-13-2013, 05:48 PM   #4
An old Tradesmen
Rewards Points: 6,962
If you currently have a 2 ton and it does a good job, no reason to increase size.
The Following User Says Thank You to beenthere For This Useful Post:
Old 02-13-2013, 08:39 PM   #5
Rewards Points: 1,022
I usually find xxx vs xxx interesting reading and I wouldn't know a good vs bad, but since I have a GE (Trane) so I'm told, I read those for entertainment.
My GE 2-1/2 ton ( non heat pump ) was installed by the contractor my builder used in 1984. I didn't have time the to research anything with the hours I was working so I didn't ask anything.
My oldest son, now in his mid 40s was 16 at the time and has had his own HVAC business in Texas for several years. He was checking it for me a few years ago and found a capacitor swollen and replaced it. Other than the capacitor replacement, me pulling the blower twice to oil and keeping the spine fin coils clean that's the only things that's been done to it in 29 years.
It has a tuff life in the summer cooling 1800 sq. ft. And speaking of tuff, he says my compressor is a recip. Climatuff and is afraid I will die of old age before the unit wears out and he will never get to sell me a new unit.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
Startingover (02-14-2013)
Old 02-14-2013, 04:17 AM   #6
An old Tradesmen
That model line was built like a tank. You won't get that kind of service out of any brand today.
The Following 4 Users Say Thank You to beenthere For This Useful Post:
ben's plumbing (02-16-2013), hvactech126 (02-14-2013), Startingover (02-14-2013), Technow (02-15-2013)
Old 02-15-2013, 09:34 AM   #7
Cruising into the sunset
JulieMor's Avatar
Rewards Points: 518
I just had a Carrier system installed about a year ago. I was told all about the cost savings, efficiency, etc. My main concern was hot & cold spots in the house. The sales rep said all will be well once the new system is in. Most promises went unfulfilled.
So it's buyer beware. I'd say shop around and get the best price. As for sizing, see if the sales guy can do a Manual J on your house. If it's done right, you should get a good idea about size.
If you like technical stuff, here's a video explaining Manual J:
JulieMor is offline   Reply With Quote
The Following User Says Thank You to JulieMor For This Useful Post:
Startingover (02-15-2013)
Old 02-15-2013, 12:41 PM   #8
thanks Julie. This is such an expensive and permanent job that I'm a bit nervous making the decision.
Old 02-15-2013, 05:45 PM   #9
The AC guy was here to give me a price. As for my bedroom getting hot at night, it's across the hall from the return air. He said when I close my door, it shuts off circulation to the return air and that's why it gets warm. For $118 he can put a bigger duct into the existing vent in my BR ceiling.
I want the Trane. The return air is about 5' from the kitchen table, and as I said, across from my BR. He said Tranes now have their fan at the base of the unit. My air handler is 30" from the return air. He asked if that would be too noisy for me. How would I know without hearing it? I turned my current (old) unit on and asked what level of noise he considered that and he said mine is quiet.
Has anyone here heard a new Trane run and do you think it's noisy?
Old 02-15-2013, 05:51 PM   #10
An old Tradesmen
A bigger vent/supply won't help if there isn't a way for the air to get out of the room.
Old 02-15-2013, 06:16 PM   #11
so you can't close a bedroom door at night?
Old 02-15-2013, 06:48 PM   #12
MarginallyQualified
If the carpet pile is that high... shave a 1/2" off the bottom of the door.
I had a rental once where I was forced to install registers in the doors.
Old 02-15-2013, 06:58 PM   #13
An old Tradesmen
IS your bedroom door under cut so that air can get out? If not, either under cut it, or have a return added to that room.
Old 02-15-2013, 07:04 PM   #14
I just see the faintest glimmer of light under the door when my door is closed. When my daughter visits and stays up watching TV the quiet and dark of having a snug door was nice. I may have to make a sacrifice somewhere.
And YAY, everyone at this AC Co are NATE certified.
Old 02-15-2013, 07:10 PM   #15
An old Tradesmen
Have a return added to your bedroom. then you won't have to sacrifice privacy.
The Following 2 Users Say Thank You to beenthere For This Useful Post:
JulieMor (02-16-2013), Startingover (02-15-2013)
Humidifier for Carrier Infinity 96 system rvmeush HVAC 1 09-19-2012 06:16 AM
Compare Carrier Model 25HNA936A003 versus Model 25HPA636 gchapman General DIY Discussions 0 11-02-2010 12:52 PM
lennox vs trane vs carrier oldfartswife HVAC 62 10-09-2009 05:23 PM
Product Advice - Trane or Carrier 99Problems HVAC 5 05-28-2009 06:23 PM
Trane Carrier XL80 fan runs constantly when switch is on jheavner HVAC 13 10-25-2008 09:54 PM
