Choices For Heated Garage? - HVAC - DIY Chatroom Home Improvement Forum
Old 09-30-2011, 03:00 PM   #1
Rewards Points: 640
choices for heated garage?
I have a completely finished and insulated garage that is 24x32
in the winter it of course goes below freezing... I want to keep it above freezing, say 40-50 degrees at most... what are some choices to do something like this? never looked into garage heat before so not sure where to start... dont need cooling, just heat
BlueBSH is offline   Reply With Quote
Old 09-30-2011, 04:13 PM   #2
Rewards Points: 268
I heat my garage with 240V baseboard heaters. I like the fact that they are quiet and take up almost no space. They would be expensive to heat every day at 70* but I only heat the garage on occasional days so its not an issue.
JackDidley is offline   Reply With Quote
Old 09-30-2011, 05:29 PM   #3
biggles's Avatar
if you have gas a radient heating strip right over the doors will catch the cold like you see in the home improvements entrances...no flue just a burner run out
Old 09-30-2011, 08:52 PM   #4
Missouri Bound's Avatar
Electric heat is 100% efficient.....and most likely the most costly. Solar works quite well....during the day. What is your fuel source? If you want to keep it relatively cool, but heat it up quickly to work in there, a gas fired unit, like a "hot dawg" would be my choice...probably $500 - 600 if you install it yourself.
Old 10-01-2011, 05:53 AM   #5
There is also a mini split heat pump. Its very cost effective when you look at the amount of energy that it uses. Plus you get to have a/c too
Master of Cold is offline   Reply With Quote
Old 10-01-2011, 08:41 AM   #6
Experienced
Jackofall1's Avatar
How about a small Reznor unit heater say 30,000 btu's/hr, that way if you want to work in the garage on the coldest day of the year you can make it more comfortable.
http://reznorunitheaters.com/
Mark
Expanding Garage INTO house (goodbye Den) texaopian Building & Construction 16 11-07-2011 10:32 PM
Garage Insulation yamster Insulation 0 07-01-2011 01:30 PM
Do I have a Fire Rating Issues with Attached Garage Perry401 Building & Construction 4 04-25-2011 11:58 PM
flooring choices for loft in garage into Flooring 0 02-28-2010 01:19 PM
