Choice Of DIY AC? - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-18-2011, 02:23 PM   #16
Rewards Points: 85
Originally Posted by yuri View Post
...You don't need one. ONLY if the compressor/condensor is 10 ft or more ABOVE the coil and has to lift the oil. Yours will be below...
*** OK, not an oil trap. Rather, an inverted loop - I guess to make triple sure that no liquid refrigerant makes its way down the suction line.
From the Goodman installation manual:
"Mounting the evaporator coil above the condensing unit will require an inverted loop in the suction line adjacent or near the connection to the evaporator. The top of the loop must be slightly higher than the top of the coil."
- JerryK
jerryk1234 is offline   Reply With Quote
Old 08-18-2011, 02:40 PM   #17
Hvac Pro
yuri's Avatar
Rewards Points: 382
Thats news to me and sounds like a bit of overkill on their part to protect the compressor but I could be wrong. If you have PROPER superheat then you will only have vapor leaving the evap coil in the last 1/4 of it. That is why it is called a superheated vapor. Read up in your refrig book about that. If they were that concerned about blowing compressors they would put an accumulator in the suction line B4 the compressor like a heat pump has. (Actually that would cost them to much $$ so they pass the cost of this loop to you?) I will check some Lennox install info to see what they recommend. (Checked and they don't mention that so I don't see it being a problem). Attic units are less than 1% of my market so there may be a reason they want that and some of the other Pros may know why. May also be that some installers don't level/slope the unit properly and they may be getting oil hanging up inside the coil and starving the compressor. The loop changes the velocity of the suction vapor and may cause better oil return.
Old 08-18-2011, 07:19 PM   #18
Rewards Points: 85
[quote=yuri;710145]Thats news to me and sounds like a bit of overkill on their part to protect the compressor but I could be wrong. If you have PROPER superheat then you will only have vapor leaving the evap coil in the last 1/4 of it.
*** Indeed. Let me play devil's advocate. Suppose that the superheat is being controlled by a TXV. When the superheat gets low ( meaning that liquid is getting close ) the TXV cranks down on the input refrigerant.
The TXV is, however, a mechanical device. It can conceivably stick wide open, drowning the evaporator in refrigerant. Which then squirts on down the line and breaks the compressor.
So the loop adds suspenders to the TXV's belt. Just a guess.
- JerryK
Old 08-18-2011, 07:28 PM   #19
Rewards Points: 392
Get yourself a 14 SEER goodman Heat pump. That's what I did and I love it! With the 14 SEER you get the super quiet compressor and fan. And a lifetime warranty on the compressor (which in the case of DIY means, higher quality). You can buy it from AC wholesalers or Route AC and have it drop-shipped to your door.. 2.5 ton unit is like 1400 bucks.
With the heat pump, you save money year round (if you're in the right climate).
My heat pump saves me 200 bucks a year and cost me ~300 more on my DIY install.
-Jeff
zootjeff is offline   Reply With Quote
Lawn seed - landscapers choice MC FORD Landscaping & Lawn Care 1 06-24-2011 04:07 PM
is Malarkey a good choice? analogmusicman Roofing/Siding 12 05-12-2010 09:48 AM
Need more power, Sub panel best choice? Hotel Electrical 6 03-07-2010 07:38 AM
Need help with unheated sunroom floor choice micimco Flooring 3 03-19-2009 09:00 AM
Wirsbo good Choice? Pex? Redoing home and might use PEX? twilightcall Plumbing 1 01-14-2008 04:43 PM
