Old 07-16-2012, 10:46 PM   #1
Chimney Venting
I recently put in a high efficiency furnace that used to be vented through my chimney. Some contractors wanted to put in a chimney vent because my hot water heater is still venting through the chimney. I have a clay liner in my chimney. Do I need to put in an additional liner?
dlmnotes is offline   Reply With Quote
Old 07-16-2012, 11:20 PM   #2
Professional
Chimney Venting
yes, you should. The clay liner is too big and water heater flue gases will condense inside the chimney and rot it out. You really should have a liner installed!
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 07-17-2012, 12:25 PM   #3
RockfordChimney
Chimney Venting
I agree, the exhaust from the hot water heater will deteriorate the mortar and clay liner, and you should install a liner. For most water heaters a 3" or 4" is all you would need. The size is calculated by the BTU's of the heater and the height of the chimney, and there should be a cap installed if you do not have one already.
Rockford is offline   Reply With Quote
How to install chimney liner Rockford How To Guides 3 07-16-2012 05:15 PM
Why a Chimney Liner? Rockford HVAC 0 07-12-2012 11:03 AM
How To Install a Chimney Liner Rockford How To Guides 0 01-24-2012 11:00 AM
gas hot water tank venting in chimney w no furnace... dbldee20 HVAC 5 02-25-2011 09:21 AM
