Chimney Size? - HVAC - DIY Chatroom Home Improvement Forum
Old 09-18-2009, 11:24 AM   #1
Chimney size?
I have aquired a free woodburner with 4 blowers, and some misc piping (stove pipe and 8" duct pipe). I have the thing in place, one blower (more than enough) attached and wired in, and the duct works is piped into my furnace ducting and to a room that is notably cold all winter long (french door, garage door, very little insulation on a concrete floor). All is well.
The chimney pipe is 7". That size is so hard to come by and so expensive when you do that I am considering either going up to 8" or down to 6". I need some advice on this. It is a large piece compared to others I have seen and is rated for coal burning as well though I doubt I ever will. I was told it would heat the entire house (3000sqft), and was used to heatr a 1500sqft garage before with no ducting, just blowing out the two eight inch outlets.
Any help would be apreciated
gdcpony is offline   Reply With Quote
Old 09-19-2009, 09:32 PM   #2
Old Newbie
Consult your insurer.
They call the shots.
Most contractors are steering away from wood installs.
It's a liability issue.
tinmanrob is offline   Reply With Quote
Old 09-19-2009, 09:39 PM   #3
GC/Master Plumber/Mech
Rewards Points: 560
What is the size of opening off the stove?
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 09-19-2009, 09:50 PM   #4
Old Newbie
Pretty sure he said 7".
Old 09-19-2009, 10:02 PM   #5
Rewards Points: 560
Pretty sure he said Chimney pipe is 7", said nothing about the size of the opening out of the stove.
Again, Pretty sure
Old 09-20-2009, 05:56 AM   #6
An old Tradesmen
Rewards Points: 6,556
Should be ok with 8".
I believe it is a code violation to go smaller then the breech opening on the wood stove.
Old 09-20-2009, 11:49 AM   #7
Old Newbie
Again, Pretty sure
I plead guilty to a poor choice of words.
No harm intended.
Old 09-21-2009, 11:26 AM   #8
Sorry, I was away for Military drills. The opening is 7" right off the back of the case. The previous owner put an elbow right there, but that can come off. I would run the pipe the same size, but getting a hold of 7" stuff is so hard and expensive. Not to mention they need 3-6 weeks to get it out.
I have it up on low bricks right now on a cement floor 30" away from the back wall and will be putting a cinderblock wall around it just to be safe. Next year I planned an addition to the garage that will put this thing in a full masonry chimney, but that is going to have to wait another year as I will be deployed then. So this has toi last safely for two years.
I was told by others I am being too safe as it is a "cased" burner (?) which I guess doesn't have the same exterior temps as my little fireplace insert. Better safe than sorry.
I can get pics once I figure out how the wife messed up the camera, but things are a mess right now out there as I take care of a few projects before bow season opens.
Chimney Confusion (Long) wehcyar Building & Construction 10 02-12-2017 07:16 AM
Chimney roof penitration size? will52100 HVAC 16 08-28-2009 04:42 PM
Roof Leak Around Chimney robertr4836 Roofing/Siding 3 03-11-2008 12:23 PM
Looks like leaking around the chimney - roofer says it is the chimney itself Salvatorparadise Roofing/Siding 6 03-07-2008 04:12 PM
