Old 03-23-2010, 07:46 PM   #1
chimney pipe question
I'm working out a supplies list for my future shed and i need help with the type of chimney pipe I need
I am putting in a wood stove and plan on sending the chimney through the roof, I want something that can come in contact with combustible materials as space will be tight. Any help on this is greatly appreciated.
naehring2000 is offline   Reply With Quote
Old 03-23-2010, 08:44 PM   #2
Master General ReEngineer
Bondo's Avatar
Ayuh,... Sounds like you'll want triple walled SSteel...
Old 03-24-2010, 07:29 AM   #3
I second that.
COLDIRON is offline   Reply With Quote
How to stop sump pump discharge pipe freezing??? relbeig Plumbing 8 11-12-2012 01:03 PM
Best way to join Poly pipe, for a water pipe repair. carl1864 Plumbing 9 08-21-2011 03:17 PM
AC Coil drain pipe questions fritzycat1 HVAC 14 11-12-2010 04:51 PM
Woodstove Chimney question in Cabin HandyDave HVAC 6 02-26-2010 10:23 PM
Possible to join PVC drain pipe to old iron pipe? darsunt Plumbing 1 07-12-2009 11:46 PM
