Chimney Modification - HVAC - DIY Chatroom Home Improvement Forum
Old 02-01-2013, 10:26 PM   #1
Chimney modification
Brand new here. I did a quick search of the forum but didn't see anybody with the same problem. I have a 2-story house built in the 70's. Top floor has a wood fireplace with a glass door. Bottom floor has a round portal into the chimney for what I'm guessing would be a pot belly stove hookup. I would like to cover up the lower floor chimney portal. The metal structure within appears to have venting around the inner flue. Can I just sawzall the metal that prodrudes from the wall, plug the hole, and put an access panel over the opening?
CoreyD is offline   Reply With Quote
Old 02-02-2013, 08:43 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,778
yes, as long as you use an aluminum cap or plug. sounds like it has a B vent chimney but you can use a single wall cap or plug
Old 02-02-2013, 09:56 AM   #3
Thanks for the prompt reply Yuri. Aren't B vent chimneys for venting gas appliances and not rated for extreme heat from wood fireplaces? This chimney vents a wood fireplace.
Old 02-02-2013, 09:59 AM   #4
Hvac Pro
yuri's Avatar
Yur right, I was just wakin up and drinkin my coffee. You have a A vent which usually has a stainless steel liner. Then you have to get a cap or plug from a woodstove dealer made of the appropriate metal to keep the insurance company happy and not degrade the chimney rating.
How to install chimney liner Rockford How To Guides 3 07-16-2012 04:15 PM
Why a Chimney Liner? Rockford HVAC 0 07-12-2012 10:03 AM
How To Install a Chimney Liner Rockford How To Guides 0 01-24-2012 10:00 AM
Looks like leaking around the chimney - roofer says it is the chimney itself Salvatorparadise Roofing/Siding 6 03-07-2008 03:12 PM
