Chimney Drafting Seems Un-Solveable - HVAC - Page 5 - DIY Chatroom Home Improvement Forum
Old 10-17-2012, 03:31 PM   #61
An old Tradesmen
Rewards Points: 7,414
That does no good at night time. And if it were to catch on fire and damage the house. You could have trouble with the insurance company.
Old 10-17-2012, 04:33 PM   #62
Obviously it doesn't work at night as it is powered by the sun. The pressure differential evens out at night and the stove doesn't back draft into the house. Did you think I light the stove with this on top of the chimney??? I said I removed it, in case you didn't see that.
MCRideout is offline   Reply With Quote
Old 10-17-2012, 05:23 PM   #63
An old Tradesmen
No, I was politely pointing out that its not a viable solution for the topic.
Old 10-17-2012, 07:25 PM   #64
Rewards Points: 610
Just wondering how attic is vented..natural roof vents/power roof vents AND how well ducts/air handler in attic are sealed..could cause negative pressure in house via duct work? Check pressures at supply and return airs with equipment off..just place tissue in front of grills to see if negative ...Just another kick at the can.
techpappy is offline   Reply With Quote
Chimney Confusion (Long) wehcyar Building & Construction 10 02-12-2017 06:16 AM
Is this a good method for repairing chimney crown/liner crack? meltdowndave Roofing/Siding 4 03-04-2010 07:56 AM
chimney leaking into attic kelley4180 Roofing/Siding 10 02-12-2010 09:55 AM
Roof Leak Around Chimney robertr4836 Roofing/Siding 3 03-11-2008 11:23 AM
Looks like leaking around the chimney - roofer says it is the chimney itself Salvatorparadise Roofing/Siding 6 03-07-2008 03:12 PM
