Checking Temp Probes - HVAC - DIY Chatroom Home Improvement Forum
Old 01-20-2013, 01:41 PM   #1
checking temp probes
Hey I posted a thread about me heatpump doing funky stuff, beenthere thought maybe the filter/drier was blocked. I went to check to temp difference across it and notice the temp was changing from just moving it .5 inch on both vapor and liquid lines. never the same reading twice!
How do I check to make sure my temp probes are working properly?
Thanks for the help
subcool is offline   Reply With Quote
Old 01-20-2013, 02:00 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,414
If you want to know they are accurate stick them on an ice cube and should read 32F. Probes and ESPECIALLY the end where leads attach to a multitester bend a LOT and eventually the wire strands break there inside the cable. I try to buy the silicon wire probes and add elect tape where they bend.
Old 01-20-2013, 05:41 PM   #3
An old Tradesmen
Rewards Points: 6,500
Ice water works better.
An ice cube out of the freezer is much colder then 32 degrees. And the part of the probe exposed to air would be subjected to a temp well above 32 degrees.
Old 01-20-2013, 06:01 PM   #4
I will do both tonight and see which gives the better measurement. I would think the ice water would work better as well, but it sounds like a great test.
Old 01-20-2013, 06:07 PM   #5
An old Tradesmen
Stir ice water and let sit for 1 minute before testing probes.
Old 01-20-2013, 06:22 PM   #6
Hvac Pro
yuri's Avatar
ice water is better but you need to use lots of ice and get the glass sweaty. have not done it for a long time but used to check the old stick type thermometers we had B4 everything went electronic.
hi temp boiler cutoff jmon HVAC 20 12-05-2012 09:01 PM
Peerless oil furnace - keeps turning on when temp exceeds target temp eugenet1979 HVAC 0 12-22-2011 09:30 PM
outdoor hot tub won't heat to temp but hold a steady temp PiPiFirecracker Electrical 11 11-24-2011 08:42 PM
boiler temp overshoot johnnyzero HVAC 0 11-08-2011 10:52 AM
AC Temp drop over plenum run length BlueBSH HVAC 23 06-22-2010 09:10 AM
