Checking Balance Of Duct System - HVAC - DIY Chatroom Home Improvement Forum
Old 11-17-2011, 05:39 PM   #1
Rewards Points: 239
Checking balance of duct system
We seem to be getting more air (and noise) out of registers close to air handler. I want to check flows from each register. I have an anemometer.
Problem is that register don't distribute flow across their faces. It blasts through wherever the boot inlet comes in, so I get a very high flow in one place and very low or zero in other places.
I am thinking of removing all registers and measuring flow right where duct enters boot. Does this make sense?
PS: this is an attic mounted air handler (heat pump)
lakeresident is offline   Reply With Quote
Old 11-17-2011, 05:45 PM   #2
Experienced
Jackofall1's Avatar
A anemometer is fine, but like you said the face velocity of the registers makes it difficult to get a valid reading.
You could always use a ribbon on a stick, look at the average angle the ribbon is blown and adjust your ducts to try and achieve a consistant look.
Mark
Using flex duct for return. lakeresident HVAC 3 11-14-2011 10:56 AM
New Heating & AC system takes long time to warm up home poston8 HVAC 10 11-10-2010 04:26 PM
I Need a New Boiler. What do i need to know New Boiler Co Plumbing 0 10-23-2010 07:03 PM
60 year old duct system with 4 inch ducts kjseattle HVAC 5 06-27-2009 10:08 PM
Replace furnace, coil and duct system sps123 HVAC 2 01-07-2006 11:56 AM
