Old 10-04-2012, 10:19 PM   #1
charging an unit
what are the first step to the last step in order form in charging an low charge ac unit for your home properly i just finish hvac school and i didnt learn what i needed from the school because of poor instructor and school thank u
astovall7 is offline   Reply With Quote
Old 10-04-2012, 10:23 PM   #2
Missouri Bound's Avatar
charging an unit
How have you determined that the unit is low on charge?
Do you want it your way or the right way?
Old 10-04-2012, 10:30 PM   #3
JJboy's Avatar
charging an unit
Do you have the test tools?
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 10-04-2012, 10:35 PM   #4
charging an unit
[quote=astovall7;102399 i just finish hvac school and i didnt learn what i needed [/quote]
Then you didn't learn anything.
Old 10-04-2012, 10:59 PM   #5
charging an unit
take the course over with another school....better to learn 1st... BEFORE YOU GET IN THE FIELD....NOT TRYING TO LEARN WHILE MAKING MISTAKES AT OTHERS EXPENSE...SORRY....ben sr
Old 10-04-2012, 11:28 PM   #6
charging an unit
Start as an apprentice or helper, that's how you will learn
hvac benny is offline   Reply With Quote
Old 10-05-2012, 12:42 AM   #7
charging an unit
nothing good to come of this... i hate to say it but you don't know enough to even be dangerous yet... lock your tools away and go back to school..... or work along side someone.... pay attention and learn
carmon is offline   Reply With Quote
Old 10-05-2012, 05:41 AM   #8
An old Tradesmen
charging an unit
Step 1. Determine if the system is actually low on charge by taking sub cooling and super heat readings.
Step 2. look for leak.
Step 3. Repair leak.
Step 4. Change liquid line filter drier, and vacuuming system.
Step 5. Add proper refrigerant until sub cooling and super heat are at there proper readings.
Old 10-05-2012, 10:25 AM   #9
Tired & Dirty
charging an unit
Go out and spend a few grand on tools & test equipment, then back to school and learn how to use them.
evapman is offline   Reply With Quote
Old 10-05-2012, 07:35 PM   #10
charging an unit
If it's a blend like 401-a, you must empty and need to refill because you don't know what happened to the freon mix.
bobelectric is offline   Reply With Quote
Old 10-05-2012, 10:00 PM   #11
charging an unit
1. Verify if there is a leak(superheat and subcool) Verifying its not a restriction, dirty coil, air flow issue with duct work.. return ect.. can go on and on (low sub cool and high superheat-leak)
2. Once verified, find leak.. replace or repair .. pull vacumm
3.Determine metering Device and freon type
4.Charge using superheat or subcool(depends on metering device)
5. Some newer Condensors have tags stating what the require depending on outside temperatures
Good Luck.. but school does help before getting on your own!
Nickhvactech is offline   Reply With Quote
Old 10-05-2012, 10:31 PM   #12
charging an unit
well if your adding refrigerant one must assume there is a leak or the system was undercharged..
Ruud Pack unit "KABOOMS" upon First Light Up of the Day! Wirenut2tite HVAC 18 12-15-2012 11:11 AM
Had an Aire-Flo AC installed, looking for opinions mikemcd HVAC 14 08-01-2011 05:07 AM
new r-410a ac unit installation procedure(w/old unit r-22)? excalibur1 HVAC 0 06-06-2011 04:47 PM
Window A/C Unit and Supplying Power JayEnder Electrical 1 04-30-2011 08:50 PM
Can't get unit to turn on need electrical help please-wiring diagram included igotshocked Electrical 32 04-15-2009 11:46 PM
