Charging R410A System Best Practice - HVAC - DIY Chatroom Home Improvement Forum
Old 04-25-2011, 05:06 PM   #1
JJboy's Avatar
Charging R410A system best practice
How you guys charge R410a system since We need charging with liquid refrigerant to the suction side. How to avoid compressor damage?
Yellow Jacket has Liquid Charger adapter....
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 04-25-2011, 05:30 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 2,276
Let it in very slowly and use a manifold that has a viewing window. Then get it so it flashes into vapor in the window at a controlled rate so you are really adding vapor.
Old 04-25-2011, 05:31 PM   #3
Rewards Points: 380
Charging adapters work fine, using your gauge manifold to meter in small amounts of liquid at a time works as well.
HVACDave is offline   Reply With Quote
Old 04-25-2011, 05:36 PM   #4
Hvac Pro
yuri's Avatar
Try NOT to do it on days under 70 deg F and you should have a good load on the unit. House temp over 70. If there is a good load then it can vaporize it better and not damage the compressor. Slug liquid in and you can damage valves, bend scrolls and wash the oil out of the compressor and then it gets damaged.
Old 04-25-2011, 05:44 PM   #5
JJboy's Avatar
Testo 550 has view windows. I can open a bit the valve on the R410a Cylinder ( Cylinder facedown ) and check in the view window right? It's gonna act like orifice.
Old 04-25-2011, 05:45 PM   #6
JJboy's Avatar
Sounds good
Old 04-25-2011, 05:46 PM   #7
An old Tradesmen
Rewards Points: 7,372
If you don't use a charge adapter/quick charge. When you meter through your manifold. listen carefully to the compressor. You can hear what is getting to it. Takes some practice though.
Old 04-25-2011, 05:48 PM   #8
Hvac Pro
yuri's Avatar
Originally Posted by JJboy View Post
Testo 550 has view windows. I can open a bit the valve on the R410a Cylinder and check in the view window right? It's gonna act like orifice
Yep, if you let it in too fast then the suction side of the gauges starts turning white, should just sweat and like I said do it on a warm day and preferably in full sunlight.
Old 04-25-2011, 05:53 PM   #9
JJboy's Avatar
I need more practice for sure. I worked 2 units this weekend. I was excited.....
Old 04-25-2011, 05:56 PM   #10
Hvac Pro
yuri's Avatar
Make sure you wear leather gloves or at least Mechanix gloves. First thing that gets a newbie is liquid refrigerant burns on his hands or he panics when a schraeder valve does not seat and gets liquid refrig on his hands. Gives you instant frostbite and removes the skin in a couple of days, NOT nice.
The Following User Says Thank You to yuri For This Useful Post:
JJboy (04-25-2011)
Old 04-25-2011, 05:56 PM   #11
An old Tradesmen
It takes time. But eventually you'll know the sounds.
Old 04-25-2011, 05:59 PM   #12
An old Tradesmen
Only takes one time for someone to learn that. Unfortunately, that one time can vary in severity from mild, to severe damage.
New Heating & AC system takes long time to warm up home poston8 HVAC 10 11-10-2010 03:26 PM
I Need a New Boiler. What do i need to know New Boiler Co Plumbing 0 10-23-2010 06:03 PM
Water Purification System - Maintenance Qs cjcocn Plumbing 1 11-18-2008 07:31 AM
Size A/C system properly 70stang HVAC 1 03-26-2006 07:22 PM
Replace furnace, coil and duct system sps123 HVAC 2 01-07-2006 10:56 AM
