-   -   Charging R410A system best practice (http://www.diychatroom.com/f17/charging-r410a-system-best-practice-102697/)
JJboy 04-25-2011 05:06 PM
How you guys charge R410a system since We need charging with liquid refrigerant to the suction side. How to avoid compressor damage?
Yellow Jacket has Liquid Charger adapter....
yuri 04-25-2011 05:30 PM
Let it in very slowly and use a manifold that has a viewing window. Then get it so it flashes into vapor in the window at a controlled rate so you are really adding vapor.
HVACDave 04-25-2011 05:31 PM
Charging adapters work fine, using your gauge manifold to meter in small amounts of liquid at a time works as well.
yuri 04-25-2011 05:36 PM
Try NOT to do it on days under 70 deg F and you should have a good load on the unit. House temp over 70. If there is a good load then it can vaporize it better and not damage the compressor. Slug liquid in and you can damage valves, bend scrolls and wash the oil out of the compressor and then it gets damaged.
JJboy 04-25-2011 05:44 PM
Testo 550 has view windows. I can open a bit the valve on the R410a Cylinder ( Cylinder facedown ) and check in the view window right? It's gonna act like orifice.
JJboy 04-25-2011 05:45 PM
Sounds good :thumbup:
beenthere 04-25-2011 05:46 PM
If you don't use a charge adapter/quick charge. When you meter through your manifold. listen carefully to the compressor. You can hear what is getting to it. Takes some practice though.
yuri 04-25-2011 05:48 PM
Originally Posted by JJboy (Post 636349)
Testo 550 has view windows. I can open a bit the valve on the R410a Cylinder and check in the view window right? It's gonna act like orifice
Yep, if you let it in too fast then the suction side of the gauges starts turning white, should just sweat and like I said do it on a warm day and preferably in full sunlight.
JJboy 04-25-2011 05:53 PM
I need more practice for sure. I worked 2 units this weekend. I was excited.....:)
yuri 04-25-2011 05:56 PM
Make sure you wear leather gloves or at least Mechanix gloves. First thing that gets a newbie is liquid refrigerant burns on his hands or he panics when a schraeder valve does not seat and gets liquid refrig on his hands. Gives you instant frostbite and removes the skin in a couple of days, NOT nice.
beenthere 04-25-2011 05:56 PM
:) It takes time. But eventually you'll know the sounds.
beenthere 04-25-2011 05:59 PM
Only takes one time for someone to learn that. Unfortunately, that one time can vary in severity from mild, to severe damage.
