Charging With R410A - HVAC - DIY Chatroom Home Improvement Forum
Old 07-03-2011, 05:09 PM   #1
Charging with R410A
Our techs have been having a lot of service calls with new unit overcharged. Many of these units were started in spring with temps below 75 degrees.,which was never a problem with R22.
Units get very noisy,and customers call. Also it seems just a half pound charge sends gauges out of site.,more finicky! Any thought appreciated.
wahoo2 is offline   Reply With Quote
Old 07-03-2011, 06:12 PM   #2
Rewards Points: 6,652
So, what is your problem again?
Old 07-03-2011, 07:20 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 1,130
Follow the superheat or subcooling chart that comes with the unit and warm the house up to 70-75 and you should not have a problem. Can safely and accurately charge a system down to 65 deg F OAT. They probably kept adding gas to try get the pressures up when it was cold thinking it was undercharged and now you can have 1/2 to 1 lb or more overcharge. Beer can cold suction line method does not work with R410 units or any over 10 SEER
R410a acessories JJboy HVAC 4 05-25-2011 09:10 PM
Charging R410A system best practice JJboy HVAC 11 04-25-2011 06:59 PM
Which works better - R410a or R22 HP/AC kb3ca HVAC 7 08-17-2010 08:50 PM
is a charging R410a same as R22 LLB62777 HVAC 8 04-08-2010 06:40 AM
Is charging a R410a system the same as a R-22 system... paulie pizza HVAC 31 06-30-2009 11:20 AM
