Old 11-24-2012, 09:14 PM   #16
charging in low temps
I know that, but even with water temperature of 65 and 110 psi that would tell me the system is charged properly
wetbar is offline   Reply With Quote
Old 11-24-2012, 09:17 PM   #17
Items wanted: Time
you are the only person in the world who can tell if a system is fully charged based on condenser water temp and the pressure of an unenergized system.
NiNe O is offline   Reply With Quote
Old 11-24-2012, 09:51 PM   #18
An old Tradesmen
A system can be under charged, and still have the same pressure as the ambient sat temp. Tells you nothing about the charge.The system must be running to tell if its charged right or not.
Old 11-24-2012, 09:56 PM   #19
Items wanted: Time
CHARGE TO 15 DEGREES F. OF SUBCOOLING.
I promise this will work, just make sure that your temps and pressures are accurate and you are reading them in the correct location.
Old 11-24-2012, 10:00 PM   #20
An old Tradesmen
15 in heating mode is a bit much on some marine applications.
Old 11-24-2012, 10:04 PM   #21
Items wanted: Time
I'll take your word for it. he has none right now, some would be better.
Old 11-24-2012, 10:08 PM   #22
An old Tradesmen
I don't think he has taken his readings for line temps at the right places.
Old 11-25-2012, 09:40 AM   #23
hvaclover's Avatar
unless I am missing something...the condenser sounds like it's scaled up.
Just slow, not stupid.
hvaclover is offline   Reply With Quote
Considering charging a 7 yr old Carrier packaged heat pump 3 ton unit illanrob HVAC 5 07-01-2012 11:00 PM
New A/C unit won't cool in hot temps wishiknewmore HVAC 39 06-28-2012 09:51 PM
re-pointing chimney in low temps bubbler Building & Construction 5 10-07-2011 01:38 PM
Return/Supply temps honola HVAC 1 09-29-2009 05:35 AM
Is charging a R410a system the same as a R-22 system... paulie pizza HVAC 31 06-30-2009 11:20 AM
