Charge Question For The Pros - HVAC - DIY Chatroom Home Improvement Forum
Old 07-22-2011, 08:14 AM   #1
Rewards Points: 332
Question
Charge question for the pros
How much would you charge for an after hours service call for a forced AC issue and also how much would you charge to fix a failed capacitor and check and top off the Freon?
tripower is offline   Reply With Quote
Old 07-22-2011, 05:12 PM   #2
JJboy's Avatar
Depends on the area that you live and the customer face ......$75-85 per pound .......$80-120 capacitor fix issue.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 07-22-2011, 07:26 PM   #3
After hours call is $156 minimum. Refrigerant is $12.64 a pound. Caps depend on which one. An average 35/5/440 is around $30.
Comparing prices from one place to the next is only going to tell you it cost less to run a business here then it does there.
Old 07-22-2011, 10:44 PM   #4
I'm Your Huckleberry
Rewards Points: 2,270
After hours call is $260, minimum.
Doc Holliday is offline   Reply With Quote
Old 07-22-2011, 11:00 PM   #5
Rewards Points: 332
Question
Thanks for the replies. I live in the Mid-Atlantic. Just trying to get a ballpark total charge for the service call, Freon and capacitor.
Old 07-22-2011, 11:23 PM   #6
An old Tradesmen
Rewards Points: 6,112
Call, 75 bucks, cap, depending on cap, 130 to 175, top off, 145 first pound(R22), 109 second and third pound.
Set & Charge AC condenser tbroertjes HVAC 2 01-05-2009 06:19 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
drywall question for the pros steve1234 Drywall & Plaster 8 07-28-2008 11:56 PM
hrv question indep HVAC 3 07-17-2008 11:39 PM
venting question any pros? THEBIGPUNN Roofing/Siding 3 02-06-2006 09:19 PM
