Charge HVAC R410a As A Gas? - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-17-2013, 10:54 AM   #16
Hvac Pro
yuri's Avatar
Rewards Points: 1,464
Originally Posted by bobelectric View Post
R 410-a is a blend. If you have a leak,you don't know what part of the freon left. Vacuum, repair leak, recharge.
It is not the system we are dealing with it, it is the actual bottle of R410. If you don't use it as liquid then the mixture in the bottle gets screwed up. Don't want the rest of that bottle being put in your system do you.
The Following User Says Thank You to yuri For This Useful Post:
statum1012 (10-17-2013)
Old 10-18-2013, 09:12 AM   #17
Good comments so far. To continue the conversation, I would like to know your thoughts on r134a? It is a blend also and on the can it tells you to rotate the can every 3 to 5 seconds when adding it to the suction line. This means it is added as a liquid and gas. Any idea what makes r134a so special that you can do this and why r410a is not as special?
statum1012 is offline   Reply With Quote
Old 10-18-2013, 11:17 AM   #18
raylo32's Avatar
Rewards Points: 1,244
I don't think R134a is a blend, hence it would have no glide so can be charged as a gas. They want you to rotate the can to help ambient heat keep the stuff evaporating so it will charge at a reasonable rate. I sometimes use a saucepan of warm water to speed things along and get the last bit out.
Live long and prosper.
raylo32 is offline   Reply With Quote
Old 10-18-2013, 11:25 AM   #19
According to many sites I have looked at it is a blend...
http://encyclopedia.airliquide.com/e...=5#GeneralData
Old 10-18-2013, 12:10 PM   #20
raylo32's Avatar
It it used as a component in other blends. But is not a blend itself....
Old 10-18-2013, 12:20 PM   #21
Interesting...I did not know that. Thanks for the clarification.
Old 10-18-2013, 05:50 PM   #22
An old Tradesmen
Rewards Points: 6,596
R134A is a single compound refrigerant. That is why it can be charged as a liquid or vapor.
However, there are companies that make bootleg R134A. It is not pure R134A, and may contain explosive additives.
Old 10-18-2013, 06:18 PM   #23
Hvac Pro
yuri's Avatar
Apparently that is a huge problem with R22 now, Kaboom. Where I am there is only one approved cylinder for sale and distribution ( no disposables ).
Tags
charge , charging , gas , liquid , r410a
Charging a 3 Phase 5 TON R410A System Proton man HVAC 5 07-02-2012 07:59 PM
Ductless Mini Split Install - need HVAC Tech! mike_30319 HVAC 13 03-30-2011 07:18 AM
Moving HVAC system dilemma denemante HVAC 4 03-18-2011 05:55 PM
How much do I charge? canadaclub General DIY Discussions 3 11-09-2006 07:04 PM
