Old 07-01-2012, 07:55 PM   #1
JJboy's Avatar
Charge Assist....is it worth it?
http://www.ebay.com/itm/AMERICAN-STA...-/220792824248
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 07-01-2012, 08:09 PM   #2
I'm Your Huckleberry
I went to an American Standard training class at a supply house a few years ago for some new condenser or another. They gave us all some kind of plug in charge assist. It allows you to walk away and concentrate on other areas of the job such as in the attic without worrying about overcharge.
I've never used it, not even sure where I put it.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 07-01-2012, 08:20 PM   #3
JJboy's Avatar
Only for American Standard Unit? Is the cable just for power or communication between charge and board control?
Old 07-01-2012, 08:57 PM   #4
An old Tradesmen
Just for A/ and Trane. And I think only for the 20i.
The Following User Says Thank You to beenthere For This Useful Post:
JJboy (07-01-2012)
Old 07-02-2012, 05:28 AM   #5
I recently took a training class at our Trane wholesaler and that's exactly what it does - you hook this up to the system, hook the cable to the control board, hook your gauge set up with the bottle in vapor mode, and then allow the system to charge itself. It basically calculates subcooling and adjusts from there. It must be used with the communicating models (I think only the 20i, although the 16i might do this as well), since those have all the sensors in place to determine the correct values.
A neat toy, but not really useful - and if you have a good thermometer and a good set of gauges, then just another toy to get lost in the toolbox!
scottmcd9999 is offline   Reply With Quote
The Following User Says Thank You to scottmcd9999 For This Useful Post:
JJboy (07-02-2012)
when is it not worth fixing? roadgypsy General Discussion 12 01-13-2012 04:04 PM
Is it worth to lose a bedroom for... fabian Building & Construction 4 11-05-2011 05:13 PM
New batteries in cordless drill won't charge Gyrobob Electrical 6 04-08-2010 12:41 PM
New Compressor - Wrong Charge? shayneb HVAC 4 08-23-2008 09:13 AM
How much do I charge? canadaclub General Discussion 3 11-09-2006 07:04 PM
