-   -   Changing Thermostat (http://www.diychatroom.com/f17/changing-thermostat-4525/)
jj2828 10-27-2006 04:26 PM
Changing Thermostat
Hello,
I'm trying to change out my old Honeywell thermostat, but getting real confuse on which one to get.
Here's what I have now.
Honeywell (can't find model anywhere on it) thermostat
120v
2 wire coming out of the wall
Heater
Hot water pump that circulate the whole house.
Pump is 0.75Amp (very small pump found in Home-depot)
I've check many sites but only found those line-voltage thermostat for dashboard electric heater. Can they be use for pump as well ?
Preferablly something that's programmable and has some kind of digital security keypad lock or something. (tennant don't understand heating bill cost 1/3 of the rent they're paying :wink: )
Would really appreciated if anyone can point me in the right direction.
JJ
#CARRIERMAN 10-27-2006 04:52 PM
Hi jj2828
The unfortunate thing about your request, they have not spent alot of time and effort promoting or even advancing much on a line voltage thermostat. The only thing you have to remember when buying one is to make sure you get one with the same amperage rating. If you get one with a lower amperage rating it will continually fail you. There are ways to convert this to a 24 volt system by using a transformer a 90290 relay and then you could put a programmable stat on it. It would not take a lot of money to do so but it will be more than another line voltage thermostat. Let us know if you need any further assistance.
Good luck
Rusty
