Changing Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 10-20-2006, 10:36 AM   #1
Question
changing thermostat
I have a oil furnace with central air. I am planing on changing the thermostat with a lux tx9000. the specs say for most 220volt systems. Looks like my furnace is 120volts and the air is 220v. Is my system 120 or 220? The new thermostat is digital and programmable with battery backup.
pappabear is offline   Reply With Quote
Old 10-20-2006, 01:04 PM   #2
Thoroughbred Mopar Man
Rewards Points: 502
Hi papabear
The thermostat control circuit for your system should be 24 volts. Do your self a favor, wrap a dollar bill around that LUX stat and throw it away. Then you will have thrown something away that was worth something. Probably the best jobber thermostats on the market are the White Rodgers 80 series. They are fairly inexspensive and are very reliable. Let me know if you need any further help.
Rusty
#CARRIERMAN is offline   Reply With Quote
Old 10-21-2006, 09:51 AM   #3
Hi Rusty Thanks for your reply.You said about the white-rodgers series 80 t-stat. Where is a good place to find one? Do home improvement stores handle them?
Old 10-21-2006, 01:20 PM   #4
Rewards Points: 502
Hi papabear
If you have a Johnstone supply,Grainger or something of that sort. They will have them, If not check with your local hardware or HVAC company.
Good luck
Rusty
Noma Thermostat vs Old Thermostat diywoman Electrical 2 01-04-2007 01:02 PM
2 stage heat thermostat problem W1 AND w2 wires whatdoIdonow HVAC 6 11-26-2006 12:04 AM
Changing Thermostat jj2828 HVAC 1 10-27-2006 04:52 PM
