Old 01-19-2009, 11:47 AM   #1
Changing the oil filter in boiler
Is it necessary to bleed your oil fired boiler, after changing the oil filter?
Thanks in advance
eefromjersey is offline   Reply With Quote
Old 01-19-2009, 12:01 PM   #2
Custom Cabinet Maker
YES, when u change the inline filter element there is a BLEED Screw at the outlet fitting, usually a 1/4" hex screw loosen that screw, change its washer, it comes with the element is the itty bitty one, leave it loose and turn oil back on when no more sir runs out and it is pure oil tighten it.
NOW is this a single or double line system????? IF single you may also have to open the bleed screw on the pump to purge it.
skymaster is offline   Reply With Quote
Changing filter in Whirlpool whole house water filter farnamct Plumbing 7 12-20-2012 10:11 PM
Burnham V7 series oild-fired boiler is turning itself off Pickngrin HVAC 6 01-12-2009 09:26 PM
Boiler w. Hydronic Air & Honeywell Aquastat DanA28 HVAC 1 01-08-2009 05:21 PM
Bypass Humidifier goes before or after air filter? key1cc HVAC 9 12-30-2008 10:12 AM
