Changing A Nozzle On A Beckett Afg - HVAC - DIY Chatroom Home Improvement Forum
Old 09-20-2010, 06:12 PM   #1
changing a nozzle on a beckett afg
I tried to remove the burner nozzle but could not get it out.
it seems that i could unscrew everything but i am afraid something would fall into the burner.
never did this b4.
changed the filter, but thats all so far.
help?
is this something that ONLY a professional should do?
johnnyd60 is offline   Reply With Quote
Old 09-20-2010, 07:05 PM   #2
An old Tradesmen
Rewards Points: 6,824
Did you pull the draw assembly out of the burner. or did you remove the burner from the furnace?
Old 09-21-2010, 07:22 AM   #3
I loosened the line that goes into the burner.
It has a little plate that slides to adjust.
Its all loose but it like there is something inside that won't allow it to come out. I could completely unscrew it but that's when i'm afraid that whatever it is that is preventing it from coming out, will fall in.
Old 09-21-2010, 04:38 PM   #4
An old Tradesmen
You shouldn't loosen that slide plate. Not unless you have the guide to reset the draw assembly position.
You disconnect the 7/16" nut, and then turn off the spline nut.
Then depending on how short the blast tube is. You have to use some force to pull the flare end on the assembly into the burner. Then spin it 180 so the electrodes are turned downward, and then it comes out sometimes easy, sometimes not too easy.
Old 09-22-2010, 10:28 AM   #5
Well i believe i put everthing back in place properly.
There were some marks left so i lined them up when i put it back together.
(that was actually before last season)
But thanks for your help.
Not sure if I'm gonna try it again.
I may call a pro.
Once i see how it is done i would certainly do it myself the next time.
Old 09-22-2010, 04:41 PM   #6
An old Tradesmen
I may call a pro.
Quiet often, it is easier to do something after you see it done once.
Beckett Oil burner ricbrk HVAC 1 08-25-2010 07:26 PM
changing brake pads on a 2001 Mercury sable with ABS deck hand Automotive Repairs 10 02-18-2010 02:57 AM
Help with Beckett oil burner newbieowner HVAC 3 02-06-2010 11:00 AM
carbon build up on nozzle zuni97 HVAC 8 01-20-2009 08:02 PM
Need Help Changing an Old Outlet AOP Electrical 6 09-03-2008 06:38 AM
